Duals with auto?
Old Sep 18, 2008 | 09:50 PM
SpecialScottie's Avatar
Duals with auto?
Is it possible to run duals on an 85 22re with stock auto tranny?
I searched but didnt find a clear answer
Old Sep 18, 2008 | 10:08 PM
scuba's Avatar
I think it is possible, but on the trails, in ultra low or w/e, your crawl ratio is gonna be huge and your breaks wont do anything
Old Sep 19, 2008 | 03:03 AM
crolison's Avatar
ditto, don't to the ultimate just do the doubler. I have heard with the ultimate the brake mounts ripping off.
Old Sep 19, 2008 | 06:10 AM
tc's Avatar
tc
Yes, but it's expensive. The only company that makes the adapter is Inchworm.
Old Sep 25, 2008 | 07:27 AM
Matt16's Avatar
Whoa, with the auto and a doubler, you going to be able to idle up just about anything. That's going to be great.
Old Sep 25, 2008 | 02:49 PM
tc's Avatar
tc
In compound low, I can idle up just about anything with a manual transmission...
Old Sep 26, 2008 | 06:55 AM
4rnr's Avatar
Im running a 3.4 into the auto (a340f) into dual inchworms with 5:1 in the rear case. My crawl ratio is 186:1 before you factor in the touque converter. which probably puts my ratio at about 400-500:1. Its rediculous.
Before that I was running the same t-case setup behind an a340h and a 3.0. It isnt that expensive.
I do however beleive dual standard cases (2.28/2.28) is plenty for the auto. I just couldnt pass up this deal I got on these cases. (built by Jim at Inchworm for the UA '06, 5:1, clocked 10*, twin stick, chromoly output...)
Heres some videos of the cases...I never use low/low/low much Im usually just in 5:1. But this whas when I first the cases and I was playing around.
low/low/low
Sorry for going so slow but there was 40 with a poor PS pump limping through the trail.
http://s4.photobucket.com/albums/y13...t=MOV03444.flv
low/low/low
Here if I was in 5:1 I would have made that with out the hesitation, but I had no momentum due to the low gears.
http://s4.photobucket.com/albums/y13...t=MOV03438.flv
BTW, my brakes will hold it in low/low/low. It has problems holding it on the street and wont hold pointed down hil, but on the trail they hold everytime.
Old Sep 30, 2008 | 08:04 AM
Blizzard's Avatar
I think the nice setup is the one that 4rnr has. I mean a "F" tranny so you can use a standard V6 adapter.
I don't have duals but I've swapped my R150F for an A343F (Almost the same that the A340F) and I love it.
David
Old Sep 30, 2008 | 02:14 PM
4rnr's Avatar
David
the 343 is the fj80 trans right...
Old Sep 30, 2008 | 02:26 PM
bigt's Avatar
no i got the 343 in my hilux surf! push button 4wd on the tcase stick
Old Oct 1, 2008 | 01:07 PM
Blizzard's Avatar
As bigt says the A343F came stock on the 3.0TD autos, Hilux Surfs and Prados. The transfer can be swapped, I put my mechanical T-Case behind the A343F.
For what I've seen on my swap, the A343F and the A340F look almost identical, maybe some ratio difference but I can't tell.
David
Old Oct 1, 2008 | 03:32 PM
4rnr's Avatar
Hmm maybe its different in the US?
There are a lot of different configurations of the a3xx series. And typically the differences are bellhousings, TC's, ratios, valvebodies, and outputs.
Daenerysdad
Oct 1, 2015 07:33 PM
noahstancik
Sep 10, 2015 10:47 AM
an1mal_69
Sep 8, 2015 09:40 AM
May-39
Sep 6, 2015 01:05 PM
