Dual case questions!?
Old Oct 14, 2010 | 06:26 PM
BoredOutnJackdUp's Avatar
so i have a top shift tcase in my truck and another one attached to a spare tranny in the garage.
And the Trail gear dual adapter is on sale right now.
and i had a few questions i couldnt find clear answers to.
Would it be a good idea to double 2.28s and do the 4.7s in the rear case at a later date when money allows?
Do i have to have twin sticks?
all i need is the two cases and adapter set?
How hard is the build?
is 2.28sX2 even worth it?
Old Oct 14, 2010 | 06:49 PM
SpecialScottie's Avatar
No you dont have to have twin sticks.
Dual cases are very easy to set up. Just follow the instructions
I have dual 2.28s in mine and thought I would go to 4.7s in the rear case at a later time but its plenty low enough for what I do. I just it just depends on what kind of trails you run
Old Oct 14, 2010 | 06:56 PM
Thanks. Thats what i was hoping for.
All i need is the two cases i have and then what comes in the kit?
Old Oct 14, 2010 | 07:00 PM
Thats correct. You have to shorten your rear driveshaft and lengthen your front. But you probably knew that already. You also have to cut a hole in the floor for the shifter
Old Oct 14, 2010 | 07:05 PM
Yeah i got that stuff.
Thanks alot man.
how much did it run you to do the drive lines? is there no way to at least run it like they are or even just the rear driveline?
Old Oct 15, 2010 | 07:58 AM
4Crawler's Avatar
The adapter and 2nd reduction adds about 6.5" to the length of the t-case, and you need to shorten the rear driveshaft by about that much. Unlikely the stock rear shaft would compress far enough to work. Check with a local driveline shop for pricing on the shaft work, or you can contact High Angle Driveline (http://highangledriveline.com/). Best to install the dual cases, then measure for the required shaft lengths.
Old Oct 15, 2010 | 05:56 PM
You can just have the rear one shortened. But I decided to get heavy wall tubing at the same time.
I made a square front shaft to save some money
the1998sr5
15
Jul 14, 2020 08:35 PM
yourrealdad
Jul 29, 2015 11:08 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
