double t-case
Old Sep 10, 2004 | 04:51 AM
big jim's Avatar
double t-case
Hey guys this is my first post. i've been reading here for a whileand this is by far the best toy forum i have found. any way i will be returning from iraq soon and i want to get a double t-case kit. i have the case. my question is dose any one know the cheapest way to do this. what parts could be scrounged ect. or mabe one of you has a kit for sale? i don't want a piece of crap but i also dont want to spend more than i need to. thank you
Old Sep 10, 2004 | 05:24 AM
fourwd1's Avatar
If you have a 2nd case, the adapter is around $400.
If you don't have a 2nd case, the adapter and required part of 2nd t-case is around $700. See Marlins website for specifics.
AA also sells an adapter also, a little cheaper I think, check their site also.
An cheaper alternative can be puting a crawler gear in your single t-case; 4.0, 4.7, or 5.0 in place of the stock 2.28. No work is needed for the front and rear drive shafts as is required for a dual case setup (hence the $ savings). The crawler gears are also around $400, from AA and Marlin.
Old Sep 11, 2004 | 12:25 PM
kyle_22r's Avatar
the only part you HAVE to buy is the adapter. there's a few places that sell them, but marlin crawler's mc07 and mc08 adapters are the the best. most of the other retailers sell marlin's mc05, which was the predecessor to the mc07. it's a good piece, but the mc07 is more durable. mc07s are about $350 right now, if i'm not mistaken. some of the other retailers have been selling the mc05 for under $300 lately
you're also going to need a transfer case. as fourwd1 said above, you can buy one as a package with the adapter or you can scrounge one from a junkyard or find one in the want ads. they're not usually very expensive, expect to pay anywhere from $75-150 for one in working order. you're going to need a top-shifted model(shifter is on the top of the transfer case, instead of in the transmission tailhousing like a forward shift case) for the rear case, they were available from '79-83 in 20R and 22R powered trucks, and '85-88 on trucks and 4runners with a 22RE engine. however, if you cant find one that's top-shift, you can buy a kit to convert it over, it's about $80
don't forget that you'll also need to have your rear driveline shortened and the front lengthened, and it may be a good time to look into a beefier transfer case crossmember/skidplate to protect your investment
Old Sep 11, 2004 | 02:26 PM
914runner's Avatar
I would just read up on Marlins site: www.marlincrawler.com
All of the info on dual cases that you would ever need!
Old Sep 12, 2004 | 12:13 PM
BeaterToyota's Avatar
This setup can be done relatively cheaply, or it can cost quite a bit. It depends how much of the work you do yourself. Also, you didn't mention what type of rig you have. For example, a Tacoma dual case setup will cost a lot more than an older rig.
Here is a list of what you'll need, and the costs that I personally spent for it:
$575 Adapter and modified donor t-case from www.inchwormgear.com
$160 For lengthening/shortening my driveshafts.
$99 For a second rubber t-case mount for the crossmember.
$10 Chome skull shift knob with light-up eyes
$10 New shifter boot for third shifter.
$260 BudBuilt crossmember.
It can probably be done for cheaper.
Old Sep 13, 2004 | 10:57 AM
fourwd1's Avatar
$10 Chrome skull shift knob with light-up eyes
That makes it all worthwhile
Old Sep 14, 2004 | 05:50 PM
TURNER's Avatar
is that shifter knob what makes your rig so capable? i knew you had a little somethin goin on in there that set you apart from all other dual-cased rigs
turner
Old Sep 15, 2004 | 01:16 PM
turner
It can't be the shifter that does it. What's the saying, "Chrome don't get you home"?
It's actually a combination of Inchworm and Budbuilt stickers. Just like blinged-out Hondas and Neons, it's all aobut the stickers.
kawazx636
Oct 6, 2021 03:03 PM
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
Ilovemountains
Sep 15, 2015 04:17 AM
