Do I really Need a adjustable Panhard Bar? TJM makes one....
Old Jul 23, 2007 | 08:20 PM
YM13's Avatar
I just ordered a 3" lift and i'm really wondering if i need a Panhard Drop Bar. I would definetely get it if it was cheaper but 200 dollars seems a lot for a bar...IMO Any alternatives would be appreciated if i really need this....
I also saw on the TJM website that they have adjustable panhard drop bars but i could not find one for sale...has anyone looked into this??
Old Jul 23, 2007 | 08:25 PM
tc's Avatar
tc
What lift are you doing?
Old Jul 23, 2007 | 08:34 PM
YM13's Avatar
Toytec OME 3"
Old Jul 23, 2007 | 08:40 PM
Knuckles's Avatar
http://www.sonoransteel.com/store_drop_bracket.html
Toyota designed the suspension to work correctly based on that bar being level, the truck will track on the street correctly with the bar level, when the suspension cycles it will react predictable and more responsive with the bar level, after all that is the way Toyota designed it. The axle will in theory droop further with a drop bracket, but in reality the rear shocks are the limiting factor. The rear shocks stop the travel long before the full RTI ramp benefits of the drop come into play. Finally the drop bracket re-aligns your rear axle and springs. With a shifted axle, the springs will sit cockeyed in the seats since they no longer line up and will wear quicker since they are constantly being squished off to an angle rather than straight up and down
your already spending money on the lift, might as well get the a new panhard bar, are you going to have to get longer brake lines as well?
Old Jul 24, 2007 | 04:35 AM
mjwalfredo's Avatar
Ditto, If you are going to be doing a lift, you might as well do it right, especially if it is going to be your daily driver. But, the panhard bar drop piece on that link that you gave is apparently discontinued.
Old Jul 24, 2007 | 06:01 AM
frodin1's Avatar
No you don't really need it, you can live with out it. However, you'll be better off just doing it right, and not half a$$ing it. I did the Tundra/890 lift and had a hard time justifying the Diffdrop. So I can see your problem with doing it. $$$$$$
Old Jul 24, 2007 | 06:03 AM
frodin1's Avatar
I should mention also, that there are numerous threads on here about people complaning about puting a lift on there rig and the rear end tracking all sideways on bumpy roads. THIS would be a panhard issue.
Old Jul 24, 2007 | 08:50 AM
YM13's Avatar
Yah I guess i should get it but what i'm asking is if I really need it....AKA will something break if i don't get it or is it just a comfort/handling issue(unlike the diff drop that could result in damage if not done from my understanding)
My only concern is that the lift costs like 360 (if u don't include the shocks with i need to replace anyways) and the bar is 200...it is over half of the price of the lift for a bar.... thats what is bothering me....
Old Jul 24, 2007 | 09:08 AM
seanz0rz's Avatar
Guest
honestly, lifting your rig cheeply is never the way to go. you will have to extend your brake line, or you will break it the first time that axle droops anymore than at ride height. as for the panhard bar, yes, you do need to either replace it, or find the relocation bracket. it is designed to be there for a reason, at a certain length for stock ride height, when you add 3" to the rear, the geometry changes and you need a longer panhard bar.
why spend the money on doing a lift if you arent even going to do it right? do it right he first time and save yourself alot of headache later. your axle will not be centered under the truck because of the design of that 4/5 link from the factory with out the correct panhard bar.
Old Jul 24, 2007 | 09:26 AM
TC4RNR's Avatar
I called steve on the same issue, for any lift over 2", yeah, you will need either an adjustable panhard bar(best/expensive) or a panhard drop bracket(better/cheaper). steve doesn't make the bracket, ProComp makes it. also Downey makes one for 3" lift too. 4crawler makes custom length for your spec. so you have plenty of choices. installing the bracket should be a 40-minute job doing yourself, i mean 1 person.
i went with Downey's 3" bracket because they are loacl for me, just 15 minutes away from my home, i don't have to wait.
Old Jul 24, 2007 | 09:42 AM
YM13's Avatar
Do the brackets have to be welded or is there a bolt-on solution....sry if this is a sutpid question i havn't looked at that part of the suspension too closely yet...
Old Jul 24, 2007 | 10:23 AM
YM13's Avatar
No, i completely understand this and that is why i went with a nice "suspension" setup instead of spacers or something else. I liked the OME setup on my friends Landcruiser and so i decided to go with it. Being in highschool i do not have very much money as I only work during the summers and its really hard to rack up enough money. The only problem that i had with this Panhard bar was that it was going to cost me 1/3 of the total lift, almost as much as my Alpine headunit, for a comparison.... thats all. I have decided i'm going to go with the drop bracket as i can't pay for the adjustable bar
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Gamble_STi
Jul 7, 2015 07:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
