Do i need to beef up my frame for winching
Old Feb 21, 2013 | 07:20 PM
Wildcat4R's Avatar
95 T4R, 3.0, 4x4, 5 spd. Mile marker sec8000 winch.
I have a 4xinnovations winch bumper on now. It has the "frame tie in plate". It only has 4 bolts on the front cross member and one bolt on each side mount. Is this enough for winching? I thought about fabbing a bracket that attaches to the 4 threaded holes under the frame and tie that into bumper. Am i over thinking this? Are 4 bolts on the front cross member enough? I am using grade 8.8 bolts.
Old Mar 15, 2013 | 05:05 PM
86reaper's Avatar
If you weld that reinforcement brace to the front of your frame, ultimately unifying the left, right, and middles pieces of the frame, you should be able to hang that truck in a tree by the front bumper...
Old Mar 16, 2013 | 03:52 AM
wyoming9's Avatar
Red face
Have you talked with Adam??
I am sure he can tell you just what you need to do
To me one can`t have to many attachment points if your getting into some heavy duty recovery work.
I always make my own crossmember that attaches to where the front hook and tie downs are.
Old Mar 16, 2013 | 06:02 AM
dropzone's Avatar
Fossilized
X2 on getting with Adam about this..He has given me great customer support
Old Mar 19, 2013 | 05:43 PM
Wildcat4R's Avatar
That was no help. When i emailed and called about fitment issues i was told it should bolt right up. I had to add 1" of steel to get the bumper out enough to mount the winch. When i emailed those pics.....no reply. Its a shame too cuz i WAS gonna buy his rear bumper.
I will prolly get the reinforcement plate from addicted and weld it on. Then bolt this all back up.
Old Mar 24, 2013 | 11:16 AM
VSIXFOURunner's Avatar
Don't know if this help.but this is how I did my winch Mount.I added some side mounts. For more Support.
Old May 6, 2013 | 07:26 PM
travisliam's Avatar
^ is that the only mounting spot or is there more? (sorry im new to this)
justdifferentials
14
Jun 11, 2017 08:36 PM
I8URSVT
Apr 17, 2016 03:38 AM
indawire
Nov 29, 2015 05:05 AM
urabus
Nov 10, 2015 07:38 PM
justdifferentials
Sep 5, 2015 06:52 PM
