The Dilema of Balancing Big Tires
This is a bubble balancer. One of my boggers took like 3 then if I remember right, had one that took 12. Just have to do each one. It's kinda PITA pending on which Beadlocks you go with. TR's won't seperate without a hydraulic tyre tool.
Spent hours jumpin up and down on them trying to beat that tire off the rim to no avail.
Originally Posted by waskillywabbit
How expensive are the Dyna Beads as I didn't see any prices on their site that I could find? I think that means
http://www.innovativebalancing.com/gallery1.htm
$40 to balance (5) 37/12.50/15s at the local tire place...they wanted to use Equal...said "no way"...they used $40 worth of lead easy...but they are much smooter now. When I beadlock the wheels...who cares then.
#25
Hey Brian... here's a Yotatecher that uses the Dyna Beads stuff if you haven't seen the thread yet... https://www.yotatech.com/forums/show...tive+balancing
I think the idea is good. I think they use them in Semi Truck tires and then there's this guy with a giant Dodge with beadlocks and claims that there isn't any vibration at all. There's also this tesimonial:
I did want to let you know that the 10oz of Dyna beads per wheel/tire combo is working great, all the way up to 75mph with absolutely no vibrations. This is with my 37x12.50-16 tires that weigh 75lb on a 16x8 wheel that comes in at 60lbs. The combo is 140lb each, about 30-40lb more than the typical combo.
Jason
Owner - http://www.pavementsucks.com"
Jason
#26
Up&Down
Aug 5, 2015 06:20 AM
DrZero
18
Jul 24, 2015 11:31 PM
