Diamond Axles: Toyota vs Dana
Would a Toyota Diamond axle with gussets, Longfields, and cryo-treated R&P be as strong as a Dana 60 style Diamond Axle?
http://www.diamondaxle.com/front_steering.htm
areyou planning on rinning King of the Rocks? or dropping in a blown ZZ572??
if not, i think that the toyota axles would be plenty strong...
plus you keep your stock width, which is a plus on the trails...
just run an fj80 axle with longs and call it done. the only reason i see for going d60 is the r&p and running deeper gears.
I would love to run an 1uzfe with r 5speed.
whose bell housing you going with?
A340F bellhousing to a 10 mm thick adapter plate. Sourced it from a guy in Oz for $20. I'll post the link to it when I get mine machined and working.
What do you mean by "Diamond style d60" Do you mean stock d-60 stuff in a diamond housing, or do you mean a blinged out chromo d-60.
I guess it doesnt matter because the answer to both is NO. The dana 60 is stronger.
Iced out D60 would be pretty pimping though haha...
Yeah that's what I was thinking...You don't think they'd even be close? 'Cause I'd like to run somewhere around 39" tires...
BTW this has been covered a million times on Pirate4x4.
Sep 4, 2015 09:27 AM
