Detroit True Trac
Old Apr 2, 2009 | 09:11 AM
88toypickup's Avatar
Detroit True Trac
I am starting to gather parts for my sas and right now my main concern is the front differential. Right now I am running an aussie in the front and a true trac in the rear and it seems pretty stupid to me to do a sas and leave the front open. I will end up having a less capable rig than a started with. Also, I am on a fairly tight budget, so the stock birfields will have to do for now. That being said here are my questions.
1. Can a take my true trac out of the rear and put it in the front? I know it will bolt in, but I thought that I read somewhere that true tracs are directional and can't be swapped from the rear to ther front very well. I have been thinking of doing this and putting an aussie in the rear.
2. If the true trac does work in the front, will the it be to much for the stock birfields? My true trac seems pretty tame, but I don't have any experience with birfields either.
3. Would I just be better off trying to sell my true trac and buying an aussie and an open carrier and hoping that the stock birfields last until I can afford to buy longfields or something similar.
Any input would be appreciated. I haven't been able to find any solid information on whether true tracs are directional or not.
Old Apr 5, 2009 | 01:04 PM
80yotaman's Avatar
I am running a welded rear and a tru trac in the front and it works good. You should be able to put the locker from the rear to the front. Tru trac is a limited slip locker, so you wont break any axels in the front. And from past experiance, its hard as hell to sell a tru trac, so i just kept mine and have never had a problem out of it.
Old Apr 5, 2009 | 03:01 PM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
Yes you can take the TT out of the rear and put it in the front. I had one for years but it was toooo tame. The birfs will be fine.
Old Apr 5, 2009 | 04:34 PM
Alright thanks, I guess I will put the true trac in the front and put and an aussie locker in the rear. How does the welded rear handle on the pavement? I have heard some people say they like it better than a locker because it is more predictable and I have heard some people say they hate it.
Old Apr 5, 2009 | 04:44 PM
86toylet's Avatar
I like it better then the locker for that exact reason. I run the spool in the rear and welded front I won't go back.
Old Apr 5, 2009 | 06:02 PM
80yotaman's Avatar
86toylet, how is the welded front as far as turning, ive heard you cant turn when lockup in front and rear. Just wondering how you like it?
Old Apr 5, 2009 | 06:08 PM
86toylet's Avatar
It is tougher, but I have a little assistance with the Hydro-Assist and twin sticks. Its just a different kind of driving.
Old Apr 5, 2009 | 08:43 PM
would you have a welded rear in a daily driver? Is it better, worse or the same as a locker in the snow/ice/rain?
Old Apr 6, 2009 | 07:06 AM
86toylet's Avatar
I would but thats me. If your in the snow, use a locker, and don't lock the front unless its selectable. I used to live in Tahoe, and I had the Detroit locker in the rear and TT in the front. It takes getting used to, and kinda scary on ice, but once you get experience its pretty nice.
Old Apr 6, 2009 | 04:43 PM
that's what I will probably end up doing. I will probably end up with the true trac in front and an aussie in the rear. Maybe I will try a welded rear for a while before I buy an aussie, I have a couple of extra open carriers.
Old Apr 6, 2009 | 04:55 PM
mikepr55's Avatar
how do the tires ware with the rear welded or with a spool mine is a daily driver but i like to be prepared when i go offroad as i do this offten. But still need it for work and such 32x1150x15 bfg a/ts and 4.88s and 3 in lift
Old Apr 6, 2009 | 05:47 PM
86toylet's Avatar
Tires get worn pretty good, just buy some new ones. Pay to play.
Old Apr 6, 2009 | 05:53 PM
tc's Avatar
tc
I HATE, I know that's a strong word, but it's still not sufficient, I mean HAAAAATE the trutrac in Molly's rig.
The trails you need a SFA for, you need a real locker. The first time you have a wheel in the air and are trying to do the brake-locker thing and getting frustrated because you know you would walk it if you could just get power to the proper side you'll know what I mean.
If the choices were trutrac front/aussie rear or aussie front/welded rear, I'd be welding that rear carrier in a heartbeat (and be saving up for a Detroit or ARB), tire wear be damned
Old Apr 8, 2009 | 12:35 PM
AxleIke's Avatar
Damn right. Seems lost on most people these days.
x2 billion.
Old Apr 8, 2009 | 12:48 PM
RustBucket's Avatar
I agree about the TT as well... I'm actually using Ike's old one (I think?) in the rear of my rig and I have had one in the front for a while. For medium stuff they are pretty cool and the brake-lock thing usually works. But the more I have used it the more that I feel that a solid half-shaft lock-up is the only way to go for anything challenging.
1uzRunner
63
Nov 10, 2018 03:58 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
taraf
Sep 25, 2015 02:57 PM
Boomer8404
Sep 20, 2015 06:15 PM
87runner_
Sep 19, 2015 03:28 AM
