cutting metal cover plate after body lift
Old Jun 26, 2008 | 04:09 PM
toyNG's Avatar
I recently installed a 2" body lift, and like many others, need to make adjustments for the transfer case shifter. I think it'll be fine if I just cut some of the metal cover plate that is underneath the boots. My question is: what's the best way to cut the plate? I guess more specifically, what tool do I need?
Old Jun 26, 2008 | 04:23 PM
HAVOC's Avatar
You should have got a shift lever extension that is welded to the shifter after it's cut. The instructions in my Performance Accesories kit mentions it. There are 2, one for each shift lever.
Is it still hitting even though you welded this in? You may have to heat and bend the shift lever.
Old Jun 26, 2008 | 04:26 PM
toyNG's Avatar
I don't think the extension would help. The metal plate is blocking me from going into 4LO because it gets in the way closer to the base of the shifter than to the top. So putting an extra 2 inches on up top wouldn't fix the problem.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
nick9455649
Sep 11, 2015 05:10 PM
Gamble_STi
Jul 7, 2015 07:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
