Budbuilt---> BudBroke
bend it back! if your going to trash it let me know i will work something out with you for it. It looks like a nice piece so if it were me id bend it back. As Troy said do it cold. What about wrapping a chain around it and fixing it to the floor somehow and jacking up on the truck if you dont want to go buck wild with a hammer. I dont know but maybe at work or something? it might take doing it one side at a time or front to back but it could work
Sorry.
It is off. It will get bent back at some point in the next week or so. Cold. I meant a good idea of doing it after a bad day at work. Beating things with hammers is a fun way to spend time!
I will look you up this winter, as i'll probably be looking to off load it. You'll get it cheap. Possibly for a couple sixers. We'll see.
For now, it goes back on. Got more trails i want to do before i go to work on this beast, and need that baby covered. Thanks though.
#27
If you lift the guts you may have to rework the front driveline CV.
http://www.4x4wire.com/toyota/tech/cvmod/
Not sure if you HAVE to but something to consider... ?
#30
Off to find a press. Whacked the hell out of it with a hammer. Then put the entire weight of the front of the truck on it. Lifted both front wheels. Nothing. Flexed down, then right back to where it was. Suck.
#33
Update.
It has been Ike fixed!
Got out the torch, cut it from both sides on the crease until there was only about 2 in left in the middle.
heated and bent it straight.
rewelded
ground it smooth.
welded 1/4" thick strap and 3/16" anle iron along the bottom. Should protect the bolt heads better now since i have hex head bolts.
Also cut a nice hole to use the drain plug.
rewelded
ground it smooth.
#35
new skid plate looks good.
#37
Without lighting the carpet on fire? I just took the pictures where there was still existing carpet
Smartass.
As for contacting Bud, I'm not going to do that. I don't need to convince Bud that he has a good product. I don't think he'd sell them if he didn't. I think that convincing the YT community that his product is excellent is a better way of helping him out. More people will buy his stuff that way.
Smartass.
