Budbuilt---> BudBroke
Old Jul 14, 2007 | 05:08 PM
AxleIke's Avatar
After two faithful years of service my bud built xcase skid finally gave up the ghost. I've gotta say, i'm impressed with the beating this thing has taken. Highly recomeneded product.
The pics are hard to see, but basically the plate folded just behind the xmember, and is now pinned against the case. This means that anytime the drivetrain is under load, it makes a horrific noise and the whole truck vibrates. Yeah. Sucky.
Not sure what i'm going to do now. Been thinking of lifting the guts, but that is a lot of work that i don't want to do right now. Perhaps the timetable has moved up eh?
Old Jul 14, 2007 | 05:14 PM
tulsa_97SR5's Avatar
Could you bend it back? Maybe take it off, flip it over and temporarily mount it upside down, then use a jack to bend it back towards straight?
Old Jul 14, 2007 | 05:25 PM
chimmike's Avatar
hack it off at the crease, weld it back on straight, and weld on some 3/8" plating to beef it up more and prevent future bends
Old Jul 14, 2007 | 05:28 PM
AxleIke's Avatar
good ideas. I'd thought about bending it back, just wasn't looking forward to the bashfest with a hammer. There isn't a lot of room to weld to it the way it is set up. I could weld to the bottom, but that will decrease my already atrocious ground clearence.
Old Jul 14, 2007 | 05:48 PM
waskillywabbit's Avatar
You should contact Bud directly.
Old Jul 14, 2007 | 06:21 PM
tc's Avatar
tc
Can you get a bottle jack up above it to push it down?
Old Jul 14, 2007 | 07:48 PM
AxleIke's Avatar
no go on the bottle jack, it would just damage my floor or my transfer case.
I'm not going to contact bud, i have no issue with his product whatsoever. Its been phenomenal all the time i've had it. Only so much abuse that stuff will handle.
Old Jul 15, 2007 | 06:57 AM
Pest's Avatar
The obvious, easy, and probably more expensive solution: Buy another one!
Old Jul 15, 2007 | 07:04 AM
Kyle95sr5's Avatar
I think the wabbit might of been suggesting to contact Bud, praise him of his great product, tell him what happened to it, and ask what he recommends to do.
Just take it off and start beating the crap out of it man, geez
Old Jul 15, 2007 | 07:07 AM
toy_tek's Avatar
Remove the plate. Take it to a metal shop where they can put it in a brake and straighten it out for you. Clean up the area on the plate where it was contacting the x-fer case. Then make a rubber isolator: Get a thin layer of high density rubber, the kind they use at loading docks, or even a slice from an old tire, and epoxy it on that spot. Reinstall the plate. Next time it bends up, you won't have metal to metal contact.
Old Jul 15, 2007 | 07:11 AM
BigBluePile's Avatar
You can get it off right? Just flip it upside down under and axle, put a jack on it and jack the truck up till the skid is straight. I had to do this for my front IFS skid by Bud, work like a champ.
Old Jul 15, 2007 | 09:31 PM
StretchASU's Avatar
X2!!!!! Dont trash it. Get a hold of Bud first and see what he says.
Old Jul 15, 2007 | 10:02 PM
86tuning's Avatar
+1.
I'm sure Bud will be happy to hear you like his product.
+1 on the 'remove it, bend it back, re-inforce it if you want, and put it back.'
Old Jul 16, 2007 | 07:16 AM
neliconcept's Avatar
Bud is in Moab or colorado Right now, Im not sure when he gets back, i think today or tomorrow
828-433-1489 = Budbuilt number
def give him a call.
Old Jul 16, 2007 | 10:44 PM
deathrunner's Avatar
That's amazing. Ican't wait to put mine on. Imagine what the stocker would have done.
Old Jul 17, 2007 | 01:14 PM
Volcom's Avatar
Can you buy just that piece that is bent?? I don't have a clue on the actual design but by looking at the pictures, doesn't it bolt onto the main crossmember piece??
Old Jul 17, 2007 | 01:34 PM
tc's Avatar
tc
Yes, it just bolts to the crossmember. No need to buy a new one, just straighten this one - the trick is figuring out how ... probably just run over it with the truck ...
Old Jul 17, 2007 | 03:16 PM
AxleIke's Avatar
Don't want to go replacement. Stock budbuilts have countersunk holes for a flat belly. I bent all the threads on the bolts, and thus they had to be cut/drilled out. There is still one in there. There are new holes drilled and G-8 bolts.
it will get bent back as soon as i have time.
Old Jul 18, 2007 | 06:51 PM
TC4RNR's Avatar
i'd wait till i had a bad day at work, come home, get a blow torch heat the bent red hot, then.... you know, BEAT THE HELL UP AT IT.
ha..'but'..dat ??
Old Jul 18, 2007 | 08:20 PM
AxleIke's Avatar
ha..'but'..dat ??
LOL. Not a bad plan at all. Might have to do that.
