On board air Q? non york compressor w/zerk fitting
Old Mar 27, 2009 | 11:51 PM
Ed H.'s Avatar
I am planning on converting my factory a/c compressor into OBA, i have been doing a lot of research on how to keep the compressor lubricated i have looked at inline oilers for intake and oil separators for the tank line. I have seen these compressors with a zerk fitting so you can just grease the compressor. My question is how is this possible i would think that it would get into the air line and cause some serious problems. Was the compressor i saw a custom unit converted to do this or can I just install a zerk without problems? Is it just best to stick with the inline oiler and separator I just want to make sure i do not burn my pump up and i would think the grease would offer the best protection. The compressor i did see was on a friend of a friend's FJ but he hadnt hooked everything up yet and couldnt offer me much info. He did tell me he bought it from somebody though.
Thanks, Ed
Old Mar 28, 2009 | 06:36 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
I do not like the grease zerk idea, yes it will get into the system. I use an oiler, then after the check valve I use a seperator. I use ATF as a lubricant for no other reason than thats readily available in my rig. My .02
Old Apr 6, 2009 | 05:32 PM
YodarStockRock's Avatar
I built OBA in my jeep using the stock AC compressor. At first I installed an inline air oiler from the local hardware store on the intake side, but when I got the AC discharged there was enough freon left in the system to keep the compressor oiled for a LONG time. I kept my separator on the exhaust side to catch all of the freon still coming out of the compressor so it wouldn't get in my tank.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
stock87yota
Jul 31, 2015 10:08 AM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
