backyard low pro bumps! + Coil spacer info
well.. my IFS doesn't flex.. but it's a bit better now
I cut the upper bump stops down about 3/8", just so that the tip of the ^ is about the line
I used a angle grinder and a big clamp. and my foot. to hold it down
a little bit better..
and for the rear.. i found out that my shocks are way short now with the spacers
this is at full droop in the rear. not bad! just need longer shocks or my next post which will be backyard budget shock spacers for cheap little old me
about 2.5" short... BUT - at full compression there is about 2.5" extra of piston exposed.. HMM......
I cut some 3" channel at work today (lucky mee I work in a steel mill) to 7" long.. I am going to weld them to the stock shock upper mount and drill a hole to space down.. boo ya.. Ill post pics as soon as I feel like busting out the welder... soon
the1998sr5
15
Jul 14, 2020 08:35 PM
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
May 20, 2016 10:27 AM
terminator
Jul 27, 2015 07:13 PM
