Auto to a 5 speed / 2nd generation
Old Oct 3, 2005 | 10:56 AM
Doc279's Avatar
Before it starts - I did search and came up with nothing !
Now - I am considering changing my 4 runner to a 5 speed from the current automatic. Anybody done this ? Will I have to change the computer ?
I can handle the mechanic's involved just wondering about the computer.
Looks like the pedal assembly would be pretty straight forward as well.
Is the cross-member different ?
Old Oct 3, 2005 | 01:37 PM
Jared's Avatar
According to ScottZ 's signature line, he has done this swap. Try PM'ing him.
Old Oct 3, 2005 | 01:40 PM
snap-on's Avatar
ya but it also says he swaped from a 3.0 to a 3.4 so is the 5sd behind the 3.4?
kinda a diffrent case than JUST swaping the trans.
Im intrested in any info also as im considering this to.
Old Oct 4, 2005 | 03:33 PM
6lug's Avatar
I Wanna Know Too!!!!
Old Oct 5, 2005 | 05:02 AM
Doc279's Avatar
Is this posted the wrong place ? I'm sure that somebody's done it.
Old Oct 6, 2005 | 08:04 AM
braverex's Avatar
I am almost done with my 3.0 Auto to 3.0 5Spd swap...
I had to buy a new rear driveshaft because the one from my Auto was a couple of inches too short so I bought a used one from a guy parting a older 5Spd.
I used a new computer but cant speak about the necessity of doing so because I didn't even try to do it with the one from my auto.
Had to modify the hole for the shift levers a little bit because it was a different pattern than the one from the 5spd. Also had to drill a hole through the firewall to accomodate for the clutch master cylinder. Few other minor things but nothing you cant figure out if you just take your time...
Any other questions... feel free to ask and I will do my best to answer!
You can see from my sig I have a 89 and I used a tranny from a 92...
Old Oct 6, 2005 | 09:43 AM
yotaman's Avatar
You can use an Auto ECU, you just have to sort some wires. I'll try and find the wire colors for you.
I'm doing this swap in a couple of weeks and will have all the information needed then.
Old Apr 14, 2006 | 09:31 PM
4runner157's Avatar
id like to know also, there needs to be a complete write up, i want to convert my 90 4runner to 5speed
Old Apr 15, 2006 | 05:52 AM
tc's Avatar
tc
Um search ... Schooler is doing it RIGHT NOW. Active thread in the 2nd gen forum.
Liadrin
Apr 25, 2022 02:54 PM
Jun 1, 2021 01:51 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 19, 2015 02:06 PM
HRDC0R19
Jul 5, 2015 06:43 PM
