Arb Air Compressor
Old May 11, 2004 | 11:43 AM
mazdamastertech's Avatar
Arb Air Compressor
i have been looking for a good mounting place for the compressor, any good spots or ideas would be nice. if possible pics would help. i have searched the forums but no luck...
Old May 11, 2004 | 12:15 PM
midiwall's Avatar
Welcome to the forum!
There are a lot of threads here on air compressors. Here're a couple "where to put it" threads:
https://www.yotatech.com/forums/f123/extremeair-arb-locker-install-has-started-need-help-28332/
https://www.yotatech.com/forums/f31/where-put-compressor-17129/
There're pics of my install in the first thread, which is also in a 96 4Runner Limited.
Old May 11, 2004 | 02:54 PM
GRNTACO's Avatar
What are going to install it in??
Old May 11, 2004 | 03:00 PM
midiwall's Avatar
His profile says he's got a 96 4Runner Limited, so that's what I'm going on.
Old May 11, 2004 | 03:03 PM
GRNTACO's Avatar
Oh yeah the profile thingy...............
Old May 11, 2004 | 09:59 PM
Tacoma Dude's Avatar
Someone mentioned a little while ago (I think it was Schaeffer) that there's a surprisingly large amount of space in the fender area behind the battery. I may put my caddy compressors there when I have time to do an install
Old May 12, 2004 | 07:36 AM
RTdawgs's Avatar
Marc Zabboth (Zman2day) has his in between the fender and the battery.
Paul (Bratik) and I have ours mounted in between the battery and the fan shroud via L brackets and Misc steel.
Old May 12, 2004 | 03:19 PM
I put mine on the fan shroud itself. I nervous but w/ the backing plate sandwiching it I gave it the old can I put my weight on it test and it held so thats where it sits for now.
Old May 12, 2004 | 03:32 PM
midiwall's Avatar
Wow... that's interesting...
Any pictures?
Old Jun 7, 2004 | 07:53 PM
well i figured where to put the compressor, how about in the rear behind the rear left trim panel. i pulled it out and there is plenty of room. the compressor is already mounted and i rewired the harness to my specs. this will keep it dry and clean just hope it is not too loud. hopefully i will have pics if i can figure out how to post them after taking them. just need to install wiring and run the line. well down time over a month now i have a locker, 4.88 gears and compressor and about 2000 later i am so ready to use it. i feel i been going through withdraws. i want to some tires spinning and some mud flying!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 8, 2004 | 05:38 AM
midiwall's Avatar
Watch out for heat build-up back there. The compressor will get VERY hot while filling tires.
Old Jun 8, 2004 | 01:15 PM
ldivinag's Avatar
ditto... early one when the ARB compressor was all i got, i neary burned my hand when i tried to disconnect the fitting.
since then i would dampen a small rag with cold water and place it around the compressor body to help it cool.
mine was mounted on the driver's side rear wheelwell. hmmmm... nothing like smelling 80 weight gear oil for a long drive home...
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
calderp
Jul 27, 2015 09:58 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
