arb and 31's or aussie and 33's
Just wondering what setup would be better for a daily driver. I cant afford 33's and a arb so if i got the arb I would have to stay with 31's. here are the choices.
-Dwney "3" lift kit (rear)
-"1.5" balljoint spacers
-15x8 M/T classic II's
-33x12.5x15 bfg mud terrains
-4:88 gears
-aisin hubs
-aussie locker
-downey "1.5" lift coils
-aisin hubs
-arb locker and compressor
-ome shocks
and stubbs slider either way. its a 93 4runner 22re tspd.
-4:88 gears
-aisin hubs
-aussie locker
-aisin hubs
-ome shocks
neither.
if you are willing to comprimise, you can easily have both of what you want.
first of all, you definitely want the 33"s and 4.88's. you want to keep your MPG's and your driveability.
if you can settle for some good used tires, you can save some cash easily. i see sets of 33" tires with 50%+ tread go for $300 sometimes less on a regular basis.
next, you dont need new wheels. use your old ones, that will save you some coin definitely. if you are hellbent on new wheels. consider these: http://www.jtoutfitters.com/product/ONSALE1
if you have the saggy but syndrome on your ride, get some coil spacers for the rear, and then do a 1" bodylift to clear the tires.
you definitely want the manual hubs, no question there.
now, as for the locker, i would go with the aussie just to save the cash, which could be put to other useful things like a powertank, etc. but you have to decide for yourself
Originally Posted by Napoleon047
neither.
-Aussie locker
-Aisin hubs
-bj spacer
-downey 3in lift kit
-rb "1" body lift
-4:88 gears
-new rims ( not decided which ones)
-33's
Originally Posted by Emurunner
Thanks for the very imformative post! i definantly need new rims because the current rims are 15x6 and I think 33x12.5 will be too wide. I guess the new plan is...
-Aussie locker
-Aisin hubs
-bj spacer
-rb "1" body lift
-4:88 gears
-33's
-Aussie locker
-Aisin hubs
-bj spacer
-rb "1" body lift
-4:88 gears
-33's
For wheels you should just go with some black rock crawlers. They usually run less than $50 a pop.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
choppe777
May 16, 2016 08:00 AM
justdifferentials
Sep 5, 2015 06:52 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
