All pro vs Marlin steering arms
Old Nov 22, 2005 | 10:23 AM
birfieldbuster's Avatar
I am getting a set of steering arms for my FJ to do the spring over. I am considering the all pro and marlin arms. I have only had experance with 4x4labs, marlins and the ones my boss used to make. the 4x4labs ones i dont like cause I am running stock springs and the tie rod tends to get crushed at full stuff. And marlins are pretty stubby, they tend to put the tie rod a little to close to the spring packs. So i should ask, are there any size diferences between marlin and all pro?
Old Nov 22, 2005 | 10:49 AM
rockota's Avatar
Marlin all the way. Much better product, IMHO. I've seen both up close, run two sets of AP's and would definitely go Marlin. Buy the 6-stud version and consider the knuckles in the future.
Old Nov 22, 2005 | 12:10 PM
Does the tie rod run as close to the spring w/an all pro setup?
Old Nov 22, 2005 | 01:30 PM
rockota's Avatar
Not sure what you mean... Spring pack thickness must always be considered.
I just hate the cast AP arms. I'll replace w/ Marlin's 6-stud once funds allow.
Old Nov 22, 2005 | 06:31 PM
waskillywabbit's Avatar
My AP cast arms that came w/ my lift kit wouldn't fit. I switched to the Marlin steering arms and will go to the 6 stud arms/knuckles if I break something relative.
Marlin for the steering arms...definitely.
Old Nov 24, 2005 | 08:40 AM
JuttyShabango's Avatar
you have to have at least 4" of lift for a high steer to work. (clear the springs) I am running AP arms right now and trying to break them so I can put the Marlin ones on. Much, MUCH better product.
Old Nov 24, 2005 | 03:39 PM
rockota's Avatar
I disagree with this; on a SFA frame, you can get away with 2" of lift, 3/4" drivetrain lift (so tie rod clears oil pan) and a reversed taper pitman arm on a properly positioned steering box. Trust me - I've seen it done and done well.
88sasturbotoy
Jan 30, 2026 01:57 PM
Braparus
42
Jun 30, 2016 12:17 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
delmert
Sep 30, 2015 04:34 PM
I8URSVT
Sep 3, 2015 11:42 AM
