Airing down tires
Old May 16, 2003 | 09:40 AM
jx94148's Avatar
I saw a guy set a bead with a ratchet strap and propane. Hose some propane in the tire, light a lighter and BOOM. It got him to 9 psi and he was on his way.
In my case I'd just hook up a hose from my converted Air conditioning pump and have all the air I need.
Old May 16, 2003 | 09:47 AM
upndair's Avatar
I don't think you'd have the air you need from the AC pump, unless you had a storage tank as well. You need to get a lot of air in fast to set the bead. Filling it up with the AC pump is no problem, but setting the bead...
I am putting in a 11 gallon air tank on my rig now. I had about 3 gallons of storage earlier but found that with 37" tires, that was only enough to inflate 2, then I was having a looooonng coffe break waiting for the next two to fill up.
Old May 16, 2003 | 09:54 PM
WATRD's Avatar
Originally posted by upndair
That method may be easy and reliable, but not necessarily safe...
That pretty much goes without saying. When you are mounting tires with a small explosion, there is a certain, inherent hazard to the operation
But, in well trained hands in a kids don't try this at home, professional driver on a closed course, contents packaged by weight not volume, contents may have settled in shipping, kind of way, it's simple, reliable, efficient and it doesn't require any fancy equipment beyond a can of starting fluid, a match and a certain level of intestinal fortitude.
Remember, before air cannons came into vogue, that is the way tire shops set a bead for many years. I can remember that being my favorite part of a visit to the tire store as a kid
The secret is in knowing how much juice to shoot in. None is not enough and the entire can is too much...
Old May 17, 2003 | 01:39 AM
jx94148's Avatar
Well, i'm not on 37s yet, And I carry ratchet straps. And I don't go so low with pressure that I lose beads. The AC pump is more than enough for my needs this season.
Old May 17, 2003 | 06:15 AM
  #25
upndair's Avatar
I was just commenting that the AC pump wouldn't be enough to reseat a tire. For everything else it may be perfect. In fact, it would be perfect if you added a reserve air tank.
Old May 17, 2003 | 02:24 PM
  #26
scott.475's Avatar
Now those are the kind of restraints I can work under!
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
94whiterunner
9
Sep 22, 2015 07:28 PM
skoti89
Jul 8, 2015 12:05 AM
