85 trany on a 80
Old Mar 18, 2007 | 06:49 AM
odtoy's Avatar
Exclamation 85 trany on a 80
1 ? will a 85 trany (5speed) bolt up to a 80 20r
Old Mar 19, 2007 | 05:09 PM
86toysr5's Avatar
i had my 20r in my first 86 and it bolted up and then my 2nd 86 we had 2 remove an alignment pin or sumthing
Old Mar 21, 2007 | 10:37 AM
MtnToys's Avatar
L series trannys will bolt right up in a pre84 truck. They are found on 83 and earlier trucks. Any 84-95 22r/e tranny (G or W series) will bolt up to a 20r 22r or 22re but they are longer then the early L trannys. So drive shaft and cross member work needs to be done if you use an 84-95 G or W series tranny in a 1st gen truck. The pre84 L series trannies have weaker bearings and are more prone to failure then the later G and W series trannies. The L43 and 45 (4 speed) are supposedly weaker then the L50 and L52 (5 speed) trannies.
If you're looking to put a G or W series in a 1st gen truck, Budbuilt.com makes some killer cross members.
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
20twinz
Sep 13, 2008 07:01 PM
co4rnr
Jul 17, 2007 05:47 AM
progress4m
12
Jan 11, 2007 07:35 AM
