6 lug wheels
Old Mar 12, 2006 | 05:00 PM
Rocklobster's Avatar
6 lug wheels
are the 6 lug pattern toyota trucks use the same as chevrolet 6 lug? Just wanted to find out before i buy a set of wheels from a chevy truck.
Old Mar 12, 2006 | 05:15 PM
89macrunner's Avatar
i think the only chevy that the bolt pattern is the same from is the k5 blazers
the bolt patter for our yotas is 6x5.5
Old Mar 12, 2006 | 05:24 PM
really? can anybody say for sure b/c these wheels are a steal and i need to let the guy know.
Old Mar 12, 2006 | 05:30 PM
marko3xl3's Avatar
Find a pic of the wheels and i'll tell you.
Old Mar 12, 2006 | 05:33 PM
dragr1's Avatar
You will need to also check the size of the center bore-if I remember correctly the spare wheel from my '04 Z-71 would not fit on my Toyota. Also the backspacing and offset should be checked.
Old Mar 12, 2006 | 05:37 PM
so it might be wise to just pass up on these wheels?
Old Mar 12, 2006 | 05:38 PM
BajaRunner's Avatar
No, most chevy lug patterns are the same as toyota.. they are 6 on 5.5
Old Mar 12, 2006 | 05:41 PM
marko3xl3's Avatar
Are Chevy rims lug-centric like Toyota's? I think someone once said they are hub-centric which would give you some vibration problems, depending on how big the difference is.
Old Mar 12, 2006 | 05:42 PM
dragr1's Avatar
They are hub centric on the Chevy.
Old Mar 12, 2006 | 05:51 PM
FYI stock backspacing on first gen rims is about 4.25in i belive
Old Mar 12, 2006 | 06:42 PM
is this going to cause a major headache then when i got to put the wheels on?
Old Mar 12, 2006 | 06:48 PM
JackKnife's Avatar
The main problem with most Chevy rims is that the center hole is too small to fit on a Toyota hub.
Old Mar 12, 2006 | 08:21 PM
Silver_Truck's Avatar
why not try em first?
Old Mar 12, 2006 | 08:41 PM
well i would test fit them but the guy isnt local
Old Mar 13, 2006 | 10:38 AM
grimpy's Avatar
I think Chevy has a big bore and a small bore... The big bore Chevy setups would fit but not the small bore...
Old Mar 14, 2006 | 06:25 PM
slosurfer's Avatar
Make sure to check the backspacing. I was looking at some rims and they said the backspacing was like 5 in. or something like that. I don't remember what year chevy they were from.
Old Dec 23, 2021 | 01:32 PM
Macm2525's Avatar
Does anyone know what brand this is
39 Thieves
Jan 6, 2017 01:08 PM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
