35s + lunchbox locker
so i did some searchin on what lunchbox locker would hold up to 35s and didnt really get a straight answer...so im asking YOU. What lunchbox locker would hold up to 35inch tires? now i dont mind spending the 250 dolla or however much it cost and i dont really wanna do a full carrier, just thought i should throw that out there....
btw the application is my sas'd t100 dana 44 front axle
thanks, colton
thanks, colton
yea i was thinking more aussie then anything but wanted to make sure. I was also thinking spartan but being one of the cheapest lockers out there that kinda scares me (you get what you pay for)
thanks for the replys!
thanks, colton
thanks, colton
I would consider talking to Mike. (MSR in post #2) I have never heard of the Spartan but he does this stuff for a living and ought to know. Bigger pins sound like a good idea to me. When something "goes" in a lunchbox, that is usually where it starts.
$750-850 per locker and something to activate them with such as an ARB compressor ($120-220) or a CO2 tank or other compressor you might have and can cobble together. If you're happy with your gears and the re-gears are relatively recent and properly done then the bearings should be good and you could likely get by with a mini rebuild kit ($60-90 per diff)
Here is how you can check for a locker.
http://www.richmondgear.com/0002pdfs/1000702MIA.pdf see pg 19
A different description of the same procedure
http://www.4x4wire.com/reviews/d44lo.../installation/ see part 3
Toyota 8" 4cyl diffs with Aussies F&R on 39.5" Iroks. So far, they've held up to 3.5 years of wheeling. CUbuff4Runner runs an Aussie in his front D44 on 36's and a 3.4 with a crawler.
I've run Genuine Gear Quick Locks in the front of my Toyota w/37 boggers for about 9 years now w/o any problems. Of course I drive with less skinny pedal, and more gears than most.
My buddy used lockrites F/R on his 82 Toyota w/22 R and 36's w/o any problems...when he went to 39.5's and a Chevy 350 the carrier expoded. This was mainly his daily driver, and he didnt use the skinny pedal much like me.
I've used lockrite's on a Ford Ranger with an 7.5 and 35's and destroyed the entire carrier. I don't blame the locker due to the 7.5 being a very weak axle anyway.
here ya go pally heres my write up of it...im not the best "write up author" so bare with me lol https://www.yotatech.com/forums/f152...00-sas-202607/
i was most likely gonna go aussie in the front...im not looking to spend big bucks and dont want a full carrier locker in the front. But anyways i called the guy from aussie and he explained to me that there lockers will take up to 40inch tires of abuse and do not have one of those "limited to over 33inch tires nonsence"
....but then i think about all the extra stuff like the air compressor i gotta get and then run the lines and do all the stuff...i just dont feel like dealing with the extra hassle...plus im doing this myself and i dont wanna screw it up or anything haha. o and i forgot to mention i know how to set up gears so ill have that covered
my pizza cutters are only 35's. Though I do wish I was selectable up front
