2nd gen 2" body lift instructions (good ones)
Old Mar 5, 2005 | 12:05 PM
-MaTTi-'s Avatar
http://www.toyotasurf.asn.au/techsite/bodylift.htm
Old Mar 5, 2005 | 12:17 PM
bike4miles's Avatar
Very good instructions. Looks like the front bumper backets might need a little modifying. It ended up tiped forward.
Old Mar 5, 2005 | 02:46 PM
Paul H.'s Avatar
" anything more than 50mm needs an engineer certificate" WOW. 50mm is about 2 inches I believe. I agree with Miles, front bumper needs work.
Old Mar 6, 2005 | 05:27 AM
leebee's Avatar
engineers certificate eh? seeing as how rb is an engineer...
lee
Old Mar 6, 2005 | 07:31 AM
4Crawler's Avatar
That is an Australian vehicle safety regulation. What they have to do with lifts of any kind over 2" is to have the vehicle fully inspected and tested, including things like rollover angle, before it can be licensed and put on the road. Some states also have height limitations on lifts, body or suspension.
Maybe I should send those guys one of my bumper brackets
I'll add that install link to my installation web page, though.
Old Mar 6, 2005 | 12:08 PM
leebee's Avatar
man, you have to come up to canada and get that truck DIRTY!
stout mounting bracket, looks good. is that included in your bl kit?
lee
Old Mar 6, 2005 | 12:21 PM
4Crawler's Avatar
Bumper brackets are included in the ktis if ordered that way. Some folks need them, some folks don't, so you get exactly what parts you need.
Old Mar 6, 2005 | 12:56 PM
jimbo74's Avatar
i ncalifornia i did some searching and a body lift to whatever hieght you want is legal as long as the floor of the body is not more than 5" away from the top of the frame
Old Mar 6, 2005 | 08:05 PM
ATP4984's Avatar
It is amazing how simple that seems after reading your write-up.
Old Jul 3, 2005 | 04:57 PM
CraZyRunner's Avatar
these instructions dont tell how to add the extension to the steering arm which you need to do cause otherwise ur screwed
Old Jul 7, 2005 | 09:25 AM
PAhydrohead's Avatar
Ahh you touched on my current question.
Roger,
I have a '92 4Runner and I'm going to do the 1.25" body lift this weekend that you sent me the stainless steel hardware for. With the 2nd gen I can just loosen the bolt in the clamp near the steering box and let the splined joint just slip apart, right?
Edit: I just reviewed Roger's website and no steering arm extension is needed for a 2nd gen. What year truck are you referring to CraZyRunner?
Old Jul 7, 2005 | 09:30 AM
RLJ3RD's Avatar
I just did a 2" body lift on my 94' Runner last weekend and I had no problems with the steering shaft. I just loosened the clamp bolt priot to lifting and retightened after. The gas filler hose caused me lot's of fits though. I also have some un-resolved shifter issues to deal with as well.
Old Jul 7, 2005 | 09:38 AM
4Crawler's Avatar
Roger,
I have a '92 4Runner and I'm going to do the 1.25" body lift this weekend that you sent me the stainless steel hardware for. With the second gen I can just loosen the bolt in the clamp near the steering box and let the splined joint just slip apart, right?
It is all covered (in agonizing detail) in the body lift kit installation instructions:
http://www.4crawler.com/4x4/ForSale/...irculatingBall
Old Jul 7, 2005 | 09:43 AM
Cool, Do you have a manual or auto? You know Roger sells a short throw adaptor plate for the manual shifters right? I bought one just in case I need it.
Old Jul 7, 2005 | 09:47 AM
There is so much good info on your website, one can get lost in there! Thanks for the link, I was having trouble finding where I previously read about the required steering mods.
Old Jul 7, 2005 | 09:50 AM
4Crawler's Avatar
There are site search boxes on some of the main pages:
http://www.4crawler.com/index.shtml
Or directly:
http://www.4crawler.com/scgi-bin/rogerb/ice2-for.pl
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Searching for "steering shaft" on either of the above search features brings you right to the page.
Old Jul 7, 2005 | 10:24 AM
RLJ3RD's Avatar
I have a manual transmission. I believe the short throw plate is for the transfer case is it not? I did trim the boot plate but the rubber shift boot is pulling the transmission shifter out of 2nd and 4th gear. I pushed the boot as far down as it will go and it still pulls. I guess my next move is to flip the boot or bend the shift lever ... anyone else got any more tips to try???
Old Jul 7, 2005 | 10:41 AM
Yea, its for the transfer case shifter. Check out Roger's website (plenty of links above), he has a solution to about every problem you can encounter.
Old Jul 7, 2005 | 11:54 AM
4Crawler's Avatar
Also working on a short throw setup for the transmission as well. Using the B&M Tacoma short throw shifter with a custom adapter plate. But flipping the boot is an easy fix for a 2-3" lift. Or raise the engine and tranny up, that is the best solution.
Old Jul 11, 2005 | 02:19 PM
Clamp bolt closest to the firewall right? Not the one down by the steering box below the rag joint. Roger's website says for a 2" lift you should expect about 1/2" of shaft extension. Is that about what you got?
