1st gen 4Runner ('89) won't start...
I bought a hot shot for mine. It should do the trick. I have the same problem. We've replaced the battery, the starter, the driver, the valve stem caps, the washer fluid, and nothing works. I think Roger is right, it's in the wiring. the hotshot should do it I'll post when I put it on. I've already had it for a month without installing it. I need some time.
Anyway, it's not just your rig.
Anyway, it's not just your rig.~S
Roger explained it on his linke earlier. It is made by painless wiring. It is a simple relay that you splice into your wiring. Instead of your ignition providing alittle current to crank your starter, that amount of current is used to open a relay wich sends full power from the battery o your starter. I guess it was designed for the crummy GM starters, but it helps our crummmy yota starters too.
Originally Posted by Amocat00
Cool. Thanks. We checked the wiring that day, but I guess it's back to that again... What exactly is a hot shot...please elaborate...
~S
~S
http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
How was the wiring checked?
#25
Originally Posted by 4Crawler
You would find that information on the web page I posted several times. In short, Painless Wiring Hot Shot starter relay kit:
Jun 1, 2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
