1997 4 Runner Tire Size Question with 3 inch lift!!!!!
Old Apr 10, 2006 | 09:17 AM
BOSTON4RUNNER's Avatar
ok here is what I have
1997 4 Runner 891s in the rear
Rev Tek in the front with the top out spacer, also have the diff drop
I am running the factory 16 X 7 alloy wheels
Can I fit 285 75 16s? I do not mind doing some minor trimming in the front i.e. front bumper, pinch weld etc, I do not have running boards and do have an offroad type rear bumper which is about 2 inches further away from the rear of the rear tires than the stock one
I hear it would be best to do a 1 inch body lift, but I would rather not, as I have another project I am working on and do not want to divert my attention from it
Please advise, I think I can live with minor rubbing, and do not mind cutting, trimming as necessary
the truck is mainly street driven but does see regular duty on the beach, often in wet, deep sand.
Thanks, Tim
Old Apr 10, 2006 | 09:19 AM
FilthyRich's Avatar
yes you can.
16x8 with 4.5" bs would be better...Oh and I have three LC wheels for sale too
Old Apr 10, 2006 | 09:39 AM
so think I will need to grind some stuff down?
I mainly drive on the street but will do beach driving
I wont be doing any heavy rock climbing etc, crawling over downed trees or the like
Old Apr 10, 2006 | 09:43 AM
ebelen1's Avatar
Originally Posted by FilthyRich
yes you can.
I thought I read here that the stock 16x7 wheels w/ 285's would rub the a-arm. Isn't that why others have gone to wheels like the LC ones because the offset works w/ the a-arms? I could be wrong but I thought this was the situation.
Old Apr 10, 2006 | 09:48 AM
FilthyRich's Avatar
it will rub a little, but for his intended use, it will be ok--not perfect, but ok.
LC wheels are ideal b/c of the size
Old Apr 10, 2006 | 11:57 AM
what year landcruiser wheels are the trick?
Old Apr 10, 2006 | 12:03 PM
FilthyRich's Avatar
93-97.
https://www.yotatech.com/forums/f180/more-fzj-80-lc-wheels-82319/
Old Apr 10, 2006 | 06:41 PM
terryjmatthew's Avatar
FWIW, I mounted a set of 285/75R16 Revos on my stock wheels and did not have any rubbing on the UCA's. It all depends on the actual dimensions of the tire.
Old Apr 10, 2006 | 06:46 PM
thanks for the input!
GreenLion
Jun 7, 2021 10:49 AM
Defy Concealment
Oct 29, 2020 11:01 AM
Tommy T.
Jul 5, 2015 07:48 AM
rondogracing
Jul 5, 2015 12:32 AM
Gamble_STi
Jul 1, 2015 12:51 PM
