99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 01:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Browse all: Toyota Tundra Cooling System Guides
Print Wikipost
Tundra temperature.. help!
Old Aug 26, 2005 | 09:11 PM
Allen's Avatar
Unhappy Tundra temperature.. help!
My AC blows very cold at 55 MPH. With successive stops and gos it starts blowing hot. Clutch, compressor,and dryer was already replaced. When in traffic, temperature gauge climbs and then AC will blow hot. I probably have to buy a new condenser (6cyl; 3.4L). Any ideas bout this?
Old Aug 26, 2005 | 11:10 PM
procast59's Avatar
Inspect for a probable partially plugged radiator. If the engine temperature is running way above normal, some of the heat is transferred to the air-conditioning condenser, which causes the air-conditioner to lose efficiency. A faulty radiator fan can also be the cause. Changing the condenser is also a good option. Find quality toyota parts at:Toyota parts.
Old Aug 28, 2005 | 05:23 PM
BigA's Avatar
Sounds to me like you need a fan clutch. Your fan is used to pull air thru the radiator and condensor. If it is not you truck will over heat and the A/C will blow hot air.
Andrew
justdifferentials
14
Jun 11, 2017 08:36 PM
ToyotaMD
Nov 9, 2015 11:53 AM
LCE_Performance
Oct 1, 2015 01:03 PM
beltcutter
Sep 30, 2015 06:14 AM
4runnerFireman
Sep 29, 2015 06:24 AM
