99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Feb 9, 2016, 04:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota Tundra Specifications & General Maintenance
Browse all: Toyota Tundra Steering & Suspension Guides
Print Wikipost
Tundra Catastrophic Balljoint failure
Old Sep 5, 2012 | 06:59 AM
milowilli's Avatar
Originally Posted by MudHippy
The mounting bolts don't fail on the second design because there's no lateral load being applied to them. As the are no longer being used to steer the wheels.
The wear shown on the ball joint stud above is not consistent with the older or newer steering knuckle designs. That type of wear would only be caused by the first steering knuckle designs used with coil spring suspensions. It's also shown next to the first design ball joint housing socket. Which suggests that I'm right in every aspect as far as my explanation for why that happened. In other words, that wouldn't happen with the second design steering knuckle.
So please quit while you're ahead here would ya? I get your point already. You obviously don't get mine. But that's just fine. You win. Let's just call it a game...
Interesting fact you mentioned on the 4x14mm bolts ..they not only have to deal with tension but also the twisting forces of the steering ..I didn't even notice that.
Old Sep 5, 2012 | 08:24 AM
xxxtreme22r's Avatar
Were those OEM ball joints? Or were they ever replaced by someone at one point? You DO NOT wheel that hard on an IFS truck and NOT change out ball joints on a regular basis. Let alone on the original set. SO either :
1: The ORIGINAL Ball Joint failed. (Your fault for not replacing them after wheeling so much)
2: The replacements either 1 failed because of inferior design. (You get what you pay for)
3: The bolts fell out of the replacement because they weren't loctited in like the FSM states.
4: The bolts fell out because they were never torqued down with a torque wrench
5: The bolts broke because they were overtorued because a torque wrench wasn't used.
Yes the design without a torsion to hold the arms in place is a poor design, but that only compounds the effect, it's not the cause.
Like Wabbit said, Designs change not just because design flaws, they change to update and strengthen, lessen the after effects of a failure, or cheaper to produce.
Old Sep 5, 2012 | 09:39 AM
MudHippy's Avatar
Well, I wasn't using the correct terminology to describe the force applied to the bolts. It's called shear load(not lateral load, though they are similar concepts, exc. lateral load refers to a type of structural load), and it's what determines the shear strength of a fastener. The bolts in question(the 4 used on the first coil spring IFS design) would be experiencing a single shear load, because they are being used in a type of single shear joint.
Shear strength is defined as the maximum load that can be supported prior to fracture, when applied at a right angle to the fastener’s axis. A load occurring in one transverse plane is known as single shear. Double shear is a load applied in two planes where the fastener could be cut into three pieces.
And I would argue that the newest design is probably just as strong as the oldest(though it's yet to be as thoroughly tested in the field to determine that it is, hence it could actually be stronger). With the one weaker design in between them.
I know the old/torsion bar IFS design is stong because I do wheel my 88 IFS hard, and I've never changed the ball joints. AFAIK, they're the original ball joints that came on the truck from the factory. And they're still holding up just fine.
Old Sep 5, 2012 | 11:39 AM
Team420's Avatar
I didnt have to change the ball joints on my 93 till I hit 220k miles... And I can say that those were some pretty rough miles! That being said... I aslo ALWAYS checked my suspension before AND after every run off the pavement. And greased them every time I went thru mud/water/snow. I also always made sure to check the mounting bolts regularly as I have seen them looen up over time. After a few year of mud/water/snow, they do tend to rust, and can come apart. I think I repleced the mounting bolts around 160-170k to avoid issues down the road...
Old Sep 5, 2012 | 01:52 PM
  #25
warpigg's Avatar
this happend to my 4runner but thats because i was using like ten dollor ball joints and they didnt have grease fitting and the ball got no grease and poped right out. but i havent had an issue since after i got the $40 napa ball joints with grease fittings.
Old Sep 5, 2012 | 11:56 PM
  #26
westjohns yota's Avatar
ball joints suck, get a soild axle, thread closed?
Old Sep 6, 2012 | 10:25 AM
  #27
warpigg's Avatar
i like the idea but ive seen knuckles fail on solid axles and its very violent and usally breaks alot of parts. when mine faild i spent $40 on a ball joint and like $40 on a front half shaft
Old Sep 6, 2012 | 12:02 PM
  #28
snobdds's Avatar
Keep in mind were dealing with a Tundra here, which would mean a heavy duty axle to swap in. Probably a Dana 60 or something similar. Guess what, those too have ball joints. So I guess the thread is still open...
Old Sep 6, 2012 | 05:57 PM
  #29
250000_yota's Avatar
I've seen plenty of bad ball joints on Dana 60s too
Old Sep 9, 2012 | 07:57 PM
  #30
Sportsmanphil's Avatar
I have to agree as a design flaw. The weight of the truck is being used to pull the joint apart and not sit ontop.
My suggestion is to learn how to properly check for lower ball joint play and check every tire rotation.
Old Sep 10, 2012 | 09:02 AM
  #31
MudHippy's Avatar
That's the correct way to look at it. Just worded differently than I did. What I mean by the coil springs pushing the upper and lower control arms apart is, the weight of the vehicle pushing up on the upper control arms/ball joints(and pulling up on the lower ball joints) against the force of the coils springs pushing down on the lower control arms(and pulling down on the lower ball joints). See Fig. 33-75 below showing how the first version coil spring IFS design works.
Fig. 33-76 shows how the newer/second version coil spring IFS design works. Fig. 33-77 shows how the old torsion bar IFS system works, except for showing a coil spring being used instead(but the operation theory remains the same).
Old Sep 12, 2012 | 11:53 AM
  #32
milowilli's Avatar
Correct!!! The load arm on these trucks is the top arm pressing down on the top balljoint..this will not fail catastrophically...no issues with First gen IFS falling apart!!
Old Sep 12, 2012 | 12:10 PM
  #33
milowilli's Avatar
Excellent illustrations!!! Finally sombody understands what I am Talking about.
Good job Mudhippy!!!
Old Sep 12, 2012 | 12:13 PM
  #34
milowilli's Avatar
Now how could a large motor car company make such a huge simple design flaw???
Design a suspension that can fail suddenly and catastrophically ...oh well!!
Old Sep 12, 2012 | 03:18 PM
  #35
milowilli's Avatar
Force arrows tell the story...compression balljoint on older an newer trucks...tension balljoint on first gen Tacomas, Tundras and 3rd gen 4Runners.
Old Nov 13, 2012 | 04:32 AM
  #36
YotaBurger's Avatar
I came across this truck last month.
Old Nov 13, 2012 | 01:35 PM
  #37
milowilli's Avatar
Nice!!! You can clearly see the ball pulled out of the socket!!!
Old Nov 13, 2012 | 01:47 PM
  #38
milowilli's Avatar
Thanks for adding the pics.
Old Nov 13, 2012 | 01:50 PM
  #39
milowilli's Avatar
I still would like to ask readers who disagree with me to show pics of first gen torsion bar IFS and Gen 3 Coilover balljoint failures!!!! Toyota dropped the ball on this first gen Coilover balljoint design..poor engineering.
Old Nov 18, 2012 | 08:20 AM
  #40
milowilli's Avatar
Old style balljoint bolts vs New style
