99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Apr 15, 2016, 10:03 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Towing & Hauling Guides
Print Wikipost
Trailer Light Question, very strange!! Help
Old Jul 30, 2004 | 03:01 PM
sworxx's Avatar
I have my 97 T100 truck wired for a trailer. It has one socket that hooks up to the truck to run the electric brakes and the all the lights. It was installed professionally. It used to work fine, but slowly one of the taillights on the trailer got dim. Then only one turn signal worked. Then they eventually went out. Alll the running lights on the trailer still work, I can turn on the lights on the truck and the trailer tailights will light, but no turn signals or brake lights. Electric brakes work too. I took the trailer and truck to a trailer place to have it checked and they said the trailer is fine. Also initially said that the truck wiring socket was fine too, but sort of questioned their testing tool. Now they are telling me that on Toyota trucks that have been wired for tow packages from the dealer have something called a "converter" and that this is probably bad. Any one know if this is feasible? I checked all the fuses, including all the extra inline ones that seem to be for the trailer and all seem fine. Anyone know what this converter is and how do I know if it's bad? Thanks.
Old Jul 31, 2004 | 08:08 AM
BigStew's Avatar
Without the trailer connected check the plug at the back of the truck. You can use a test light style tester, where you clip one end to ground then it lights up when probing the connector. Have some else in the cab turning on the lights, turn signals, etc. Even though you have running lights on the trailer I think you have a bad ground between the trailer and the truck.
I had a 4th gen 4Runner and rented a U-Haul trailer. The U-Haul dealer had to run a ground wire from the trailer side to the 4Runner's trailer connector to get everything to work. It was just not a good enough ground via the receiver hitch.
Good Luck
Old Jul 31, 2004 | 08:25 AM
bigbadktm's Avatar
same trouble on my t100 with a bad ground.
Old Aug 1, 2004 | 09:52 AM
sworxx's Avatar
Ok, it was not a bad ground it did indeed end up being this converter. The trailer place replaced the converter and the problem was solved.
Old Aug 5, 2004 | 01:37 PM
BigStew's Avatar
I am glad it is working. I hope it wasn't too big of a hit in wallet.
the1998sr5
15
Jul 14, 2020 08:35 PM
DrZero
18
Jul 24, 2015 11:31 PM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
toyota32
Jul 6, 2015 05:42 PM
