99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
bad bearing somewhere?
Old Nov 3, 2010 | 08:26 AM
wellyman's Avatar
Hey all:
I have an 04 DC 4x4 tundra that is making what sounds like a bad wheel bearing noise, or chopped tires, that can be heard from 10-50 mph. it seems to be most noticeable around 45mph. It does almost go away when I turn RIGHT, which got me thinking it was the passenger side wheel bearing. There is some vibrations that accompany the noise, which can be felt in the floor. The tires are fairly new, maybe 10k on them. I decided to drive on it some hoping it would get a little worse and diagnosing it would become easier, but it started getting to me, so I replaced the front passenger wheel bearing, and its still there. When I had the front pass wheel off the ground during diagnosis, I could hear/feel roughness when I turned the tire. So now I'm thinking it's at the front differential.
I'm looking for any suggestions on how I can pinpoint the problem, as I'm at a loss.
Thank you all in advance for the brainstorming efforts...
Old Nov 4, 2010 | 12:11 PM
jim65wagon's Avatar
Check the CV joints before you dig into the diff....
Old Mar 31, 2011 | 04:32 PM
Yardbird's Avatar
Originally Posted by wellyman
Hey all:
Did you ever figure out this problem? I have an '02 Sequoia that is doing the exact same thing. I replaced the right wheel bearing, then the left. Neither fixed the problem. I would be real interested to see what the deal was with your Tundra ... I may have the same issue.
Thanks!
Old Apr 1, 2011 | 03:14 AM
wellyman's Avatar
my issue ended up being a wheel bearing. i did one side and then had to do the other as i guessed wrong. i do hear a slight noise again, and im hoping its just tires. carrier bearing should be checked. good luck to you.
Old Apr 1, 2011 | 05:29 PM
Yardbird's Avatar
Thanks for the insight ... I appreciate it!
Old Apr 13, 2011 | 06:16 PM
Yardbird's Avatar
Update ... mine was the LR wheel bearing. Got it up on a lift and listened with a stethoscope. The LR bearing was just a little bit more noisy than the RR ...
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
