99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
4x4 Light
Old Oct 17, 2003 | 03:02 PM
AndroT100's Avatar
4x4 Light
My 4x4 light does not turn on when I move from H2 into H4 or L4. Although I haven't taken my truck down to a spot to definitively check it still goes into H4 and/or L4... it seems to be doing it in my gravel driveway! I will check this. Question is, anyone know what I should check first regarding the light besides actual engagement? Where does the lead run?
Many thanks.
Old Oct 20, 2003 | 06:25 AM
WileEToyote's Avatar
There's a pigtail that plugs into the front diff that's easy to pull out and would be the simplest problem/solution.
Old Oct 20, 2003 | 09:13 AM
AndroT100's Avatar
Checked it
Thanks for the word.
I did go under and check. The line looks intact and not too dirty after 124k miles. The vacuum lines look intact also. I suppose the next thing to do is disconnect and clean the contacts if dirty and reconnect.
I'll keep you posted.
Old Oct 20, 2003 | 02:46 PM
BigA's Avatar
4x4 Light
Have you checked the bulb in the dash? Mine went out not to long ago on my T100. I doubt that the contacts are dirty on the switch on the front axle ( they are sealed well from the factory). Also I think there is also a switch on the tcase.
Andrew
Old Oct 20, 2003 | 04:36 PM
AndroT100's Avatar
Light-out
No, I haven't gone in the dash...Toyota service said it is a bear of a job to get to it. Not sure if this is true. Where is the switch on the transfer case...right, left, up, down?!
I am not knowledgeable of how the system actually engages the 4 wheel drive...of course it is a manual shift, but is the engagement of the front hubs electronic and/or vacuum as I assume, and the shift is for the transfer case?
Thanks.
Old Oct 20, 2003 | 08:02 PM
BigA's Avatar
Post
This is on the T100 right? If it is the dash cluster comes out by removing the trim piece and a few screws (also put the steering column all the way down). The Switch is on the back of the Tcase (I think) between the rear output and the front output. I dont know if this does anything for the light though.
Andrew
PS: It would take a whole page to show the 4x4 engages, but if low range works, most likely everything but the light is working.
Old Oct 20, 2003 | 08:20 PM
AndroT100's Avatar
T100 Light-Out
Yes...it is the T100.
Thanks for the info. The low-range does work! So, I'll take a look at getting the cluster out and checking the bulb. I have looked at this dash for 124k miles and even so, I can't picture the trim piece you are speaking of. So come morning, I'll check-it-out.
Thanks again.
Old Oct 21, 2003 | 04:32 AM
BigA's Avatar
Post
I may be wrong about the trim piece, but I know that the cluster isn't that bad to pull out. I had to replace a few bulbs (including my check-engine light ), but I didn't remove it so I dont care. Hope that helps.
Andrew
Old Oct 21, 2003 | 09:09 AM
The trim/"window" of the dash is that easy - 4 screws. Hardest part is wiggling it out without worrying yourself to death that you might crack something.
raptor510
Feb 17, 2017 07:11 AM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
