99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old 03-18-2016, 12:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra 4WD - Four Wheel Drive Guides
Print Wikipost
4x4 failing to engage
Old 11-28-2004, 05:43 PM
wiser696's Avatar
Question 4x4 failing to engage
The 4wd has been acting weird lately on my 95 T100. If I start the truck cold or let it sit for 1/2-1hr and go from 2H to 4H 4wd engages and the 4wd light comes on. If I take the truck down the road for a drive then decided to ˟˟˟˟ from 2H to 4H stopped or rolling the 4wd light doesn't come on and the 4wd doesn't engage. I have found this after getting stuck in the mud. When the light does come on the 4wd works great. Has anyone else run into something similiar to this?
thanks
Matt
Old 11-29-2004, 01:55 PM
WileEToyote's Avatar
thanks
Matt
check and see that the wiring harness is clean and still attached to the front differential
Old 11-29-2004, 05:09 PM
BigA's Avatar
Make sure that the vacum lines to engage the frontend are in good shape (on one trail ride I broke the one that engaged the four wheel drive) and that the vacum solenoids are working. Also at times it may take some time for the everything to line up, so shift it and see if engages after a few feet. Also make sure that the truck is making a good vacum signal because that is what truly engages the fourwheel drive.
Andrew
Old 12-01-2004, 03:37 PM
wiser696's Avatar
So far I have checked the vacuum lines and they all are getting suction. Any other possibilities?
Old 12-01-2004, 05:16 PM
BigA's Avatar
The slider inside of the axle may be stickey then. Try taking it out. It shouldn't be too bad (four bolts I think). Also change your gear oil when you are in there. If there is any water or other types of debris in there, it could mess stuff up.
Andrew
Old 12-01-2004, 05:24 PM
BigA's Avatar
Did you check to see if you have vacum on both lines at the same time. If that was happening then the slider can't move. In that case the controller is bad. Just something else to look into.
Andrew
Old 12-07-2004, 03:02 AM
wiser696's Avatar
I finally got a chance to change the front differential oil, and test drive. I was a bit sckeptical that changing the oil would solve the problem, but so far it seams to have worked.
Jdgarrison
10-01-2015 05:22 PM
tomczaksdiesel
07-26-2015 10:35 PM
toofly1999
07-25-2015 07:09 PM
1994toyota
07-17-2015 03:03 AM
jgwerth
07-16-2015 03:23 PM
Quick Reply: 4x4 failing to engage
