99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2004 Tundra Odo / Speedo Faillure
Old Sep 6, 2011 | 09:39 PM
Brule's Avatar
I have a 2004 Tundra (V8 -auto) with approx 117km on it and the Odo and Speedo have stopped working or will work intermittently. Local Toyota dealer says that I have to buy a whole new unit. But based on the random workings of it, I think that it has to be a sensor that needs adjusting. How can I find where the sensors and pick ups for them are at?
Thanks,
Old Sep 6, 2011 | 10:45 PM
scuba's Avatar
There is a 3 wire vehicle speed sensor on the passenger side of the transfercase at the back end (assuming you have 4x4). If you have a 2wd, it should still be on the back end of the tail housing near the driveshaft flange.
My guess is either the sensor is dying, the gears inside the housing have stripped, or you have a frayed wire causing a short between the VSS and the ECM or the ECM to the gauge cluster.
The first picture in this thread shows where the VSS is on a 4x4 truck.
https://www.yotatech.com/forums/f2/w...brator-213419/
Old Sep 9, 2011 | 09:36 PM
Brule's Avatar
Thanks Scuba, I will get under there and have a thorough look at it tomorrow in the day light. it has to be something simple like that as it kicks in and out, so I believe it's loose and also don't wanna spend close to $500 to fix it at the shop.
Old Sep 10, 2011 | 12:06 PM
Brule's Avatar
As you can see, I am looking at a different set of hoses here - any suggestions?
Thanks,
Old Sep 10, 2011 | 12:18 PM
scuba's Avatar
Thats odd.
Check out the FSM for the exact location of the speed sensor
http://www.ncttora.com/FSM/00-03-Tun...Tundra_FSM.pdf
ToyotaMD
Nov 9, 2015 11:53 AM
LCE_Performance
Oct 1, 2015 01:03 PM
beltcutter
Sep 30, 2015 06:14 AM
4runnerFireman
Sep 29, 2015 06:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
