99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2002 Sequoia TDC Question (Timing Belt)
Old May 29, 2011 | 02:45 PM
georgia 4Runner's Avatar
I am trying to change the timing belt and have two questiosn in regards to TDC if you do not mind:
1) If I have the vertical marks on cam sprockets aligned with backing plate vertical lines (plate with "T" as well), do I have it at TDC. I htink so, but not sure.
2) If I have the two cams with vertical lines on sprockets and backing palte aligned, but my timing mark at crank is about 5 degrees is that OK?
Thanks in advance.
Old May 30, 2011 | 03:48 PM
I have an new issue. I did the timing belt, repalced oil and spark plugs (as i was already in the mode) and then strated car. it did not run smooth at all. I shut it off and went back thru everything I ahd done and recalled that I left the left the belt tensioner pin in. So i removed it, but the car will not idle now. It has a 1126 code. Any ideas? Did i mess up the timing belt or other issue. thanks.
Old May 30, 2011 | 08:01 PM
figured it out...throttle motor connectoer was loose.
Old Jun 21, 2011 | 06:18 PM
sseaman's Avatar
It is nice to figure things out yourself
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
