Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics
Old Aug 20, 2021 | 10:37 AM
Diode Dynamics's Avatar
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-7o7uyqg.jpg
If you are looking to add driving lights to your 4Runner, check out the Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner from Diode Dynamics!
The SAE/DOT LED Lightbar Kit for the 2014-2021 Toyota 4Runner from Diode Dynamics allows you to mount a pair of SS6 Stage Series 6" Light Bars in the upper grille opening and provides road-legal output as Driving Lights. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling is required!
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-casc890.jpg
Street Legal Output. This kit isn't just for off-road! It is legal for on-road use as driving lights (Please check your local laws and regulations for aiming, installation, and applicability). With the included plug-and-play wiring harness, you can control the kit through your toggle switch.
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-fbt7gzk.jpg
Designed For Performance. Using optical simulation modeling, Diode Dynamics Stage Series light bars have been designed for maximum functionality, with compact size, custom-engineered TIR optics, and a useful beam pattern, all in a highly durable package. Our light bars shine light in a highly-functional and useful beam pattern, much more focused than older LEDs on the market.
Functional Patterns. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
  • The Wide pattern provides an extremely wide field of view, without wasting any light in the sky above and provides a 100Wx8H degree spread of light. It was designed to supplement your fog lights and is perfect for driving in inclement weather.
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-1eq9q48.jpg
White or Amber. All Stage Series Light Bars are available in a cool white or amber. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The amber color output, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your Stage Series LED Light Bars.
Bolt-On Installation: The thick-gauge stainless steel brackets in this kit were CAD-designed to utilize existing mounting points for a bolt-on installation - there is no cutting or drilling required!
In the Box:
  • Two (2) application-specific SS6 brackets for installation on the 2014-2021 Toyota 4Runner
  • Two (2) SS6 Stage Series lightbars
  • One (1) heavy-duty dual-output wiring harness
  • Mounting hardware and guide
NOTE: Compatible with all 2014-2019 trims, but only compatible with 2020-2021 TRD Pro trim package.
See how to install our Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner!
Click HERE to check out the replacement outer lenses for our Stage Series Light Bars!
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-b0pelig.jpg
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Old Sep 2, 2021 | 08:45 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-cgzmpud.jpg
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Stage Series Light Bar Kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Cannot be combined with other coupon codes.
*Sale excludes preorders.*
Old Sep 7, 2021 | 08:02 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-8uqdkrw.jpg
Just a reminder! We just released our NEW Diode Dynamics flag shirt!
All orders over $300 during our Labor Day Sale will receive one free! If you're interested in purchasing a shirt, we have them listed under the gear section on our website.
John C.
Diode Dynamics
Old Sep 10, 2021 | 06:26 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-ubtkiuu.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Oct 7, 2021 | 07:20 AM
FormerVendor
What sets our Stage Series light bars apart from all others?
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-7cmqssq.jpg
They feature patent-pending Total Internal Reflection (TIR) optics that not only focus the light but reduce glare!
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-cdka9ut.jpg
John C.
Diode Dynamics
Old Nov 22, 2021 | 01:14 PM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-rvm46eq.jpg
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our Stage Series Lightbar Kits, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Old Nov 30, 2021 | 07:56 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-minb4vt.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Old Jan 21, 2022 | 12:54 PM
FormerVendor
All Stage Series LED light bars are IN-STOCK!
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-ltjpzhf.jpg
Just a reminder, all US forum members are eligible for a free shipping code. Just PM us!
Old Apr 13, 2022 | 10:53 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-nex2ulw.jpg
For the month of April, we're throwing in a FREE Diode Flag Tee when you spend $300 or more.
Click HERE to shop your ride!
Old Jun 30, 2022 | 08:40 AM
FormerVendor
Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner! | Diode Dynamics-tije4yj.jpg
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping during checkout.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Old May 25, 2023 | 11:48 AM
FormerVendor
🚨 Our Memorial Day Sale is LIVE!!! 🚨[/CENTER]
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
