Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics
Old Aug 25, 2021 | 08:45 AM
Diode Dynamics's Avatar
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-knlyhoo.jpg
If you spend time off-roading and need more light output, check out the Stage Series Stealth Light Bar Kit for the 2014-2019 Toyota 4Runner from Diode Dynamics!
The Stealth LED Lightbar Kit for the 2014-2019 Toyota 4Runner from Diode Dynamics allows you to mount either a single SS30 Stage Series 30" LED Light Bar or dual Stage Series 30" LED Light Bars in the lower grille opening. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit retains the factory grille for a clean, OEM-like appearance.
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-zosdsg5.jpg
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-quodu52.jpg
Choose your look. The brackets included with this kit were designed for full customization. They feature multiple mounting holes, so you can mount a single 30” light bar or dual 30” light bars behind your grille and achieve the look you're after.
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-8hmmwlf.jpg
Designed For Performance. Using optical simulation modeling, Diode Dynamics Stage Series light bars have been designed for maximum functionality, with compact size, custom-engineered TIR optics, and a useful beam pattern, all in a highly durable package. Our light bars shine light in a highly-functional and useful beam pattern, much more focused than older LEDs on the market.
Functional Patterns. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
  • The Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 20Wx8H degree pattern while also illuminating the area around it in a full 80Wx50H degree spread. The Stage Series 30" Combo Light Bar features three driving lenses in the middle with two flood lenses on the outer edges
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-acfsclf.jpg
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your Stage Series LED Light Bars.
Bolt-On Installation: The thick-gauge stainless steel brackets in this kit were CAD-designed to utilize existing mounting points for a bolt-on installation - there is no cutting or drilling required!
In the Box:
- Two (2) application-specific SS30 brackets for installation on the 2014-2019 Toyota 4Runner
- One (1) or Two (2) SS30 Stage Series lightbar(s)
- One (1) heavy-duty dual-output wiring harness
- Mounting Hardware
- Installation Guide
NOTE: This kit is not compatible with the Limited or Nightshade trim levels.
See how to install our Stage Series Stealth Light Bar Kit for 2014-2019 Toyota 4Runner!
Customizable: If you’re looking to change the output color or beam pattern of your Stage Series Light Bars. We offer replacement polycarbonate outer lenses in our driving, wide, or flood beam pattern options in amber or clear!
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Old Sep 2, 2021 | 08:49 AM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-cgzmpud.jpg
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Stage Series Light Bar Kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Cannot be combined with other coupon codes.
*Sale excludes preorders.*
Old Sep 7, 2021 | 08:06 AM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-8uqdkrw.jpg
Just a reminder! We just released our NEW Diode Dynamics flag shirt!
All orders over $300 during our Labor Day Sale will receive one free! If you're interested in purchasing a shirt, we have them listed under the gear section on our website.
John C.
Diode Dynamics
Old Sep 10, 2021 | 06:30 AM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-ubtkiuu.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Old Oct 7, 2021 | 07:24 AM
FormerVendor
What sets our Stage Series light bars apart from all others?
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-7cmqssq.jpg
They feature patent-pending Total Internal Reflection (TIR) optics that not only focus the light but reduce glare!
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-cdka9ut.jpg
John C.
Diode Dynamics
Old Nov 22, 2021 | 01:18 PM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-rvm46eq.jpg
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our Stage Series Lightbar Kits, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Old Nov 30, 2021 | 08:00 AM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-minb4vt.jpg
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Light Bar Kits, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Old Jan 21, 2022 | 12:58 PM
FormerVendor
All Stage Series LED light bars are IN-STOCK!
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-ltjpzhf.jpg
Just a reminder, all US forum members are eligible for a free shipping code. Just PM us!
Old May 26, 2022 | 12:14 PM
FormerVendor
Bolt-On Stage Series Stealth Lightbar Kit for 2014-2019 4Runner! | Diode Dynamics-ei69vni.jpg
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
Old May 25, 2023 | 11:48 AM
FormerVendor
🚨 Our Memorial Day Sale is LIVE!!! 🚨[/CENTER]
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
