Diode Dynamics: 2014+ Toyota Tundra Light Bar Kit! See Installation Video!
Sponsor
2014+ Toyota Tundra Light Bar Kits
Diode Dynamics is excited to announce the release of 3 new light bar kits for the 2014+ Toyota Tundra! These Toyota Tundra-specific kits feature CAD-designed bracketry that enables you to install up to a 42" Stage Series Light Bar for dramatically upgraded visibility without any permanent modification to your Tundra's body or bumper!
(installation video below).
First up is our LED Driving Light Kit for the 2014+ Toyota Tundra. With the included application-specific brackets, you're able to bolt-on two of our 12" Stage Series Light Bars neatly behind the grille, using factory mounting points. No cutting or drilling required! These brackets were designed right here in the U.S.A, and built with powder-coated steel for maximum durability.
The high-beam adapter harness (also included), means the dual 12" Stage Series Light Bars are automatically activated with the high beams, providing dramatically more nighttime visibility than bulbs alone.
This kit features everything you need for installation, including:
Bracket set
2 SS12 12" Stage Series Light Bars
Dual output harness with H4 high-beam adapter
All necessary hardware
Installation guide
In addition, Diode Dynamics is also proud to announce our Stealth Lightbar Kits for the 2014+ Toyota Tundra! These Tundra kits include application-specific brackets to mount either a 30" or 42" Stage Series Light Bar in the factory lower grille. The 30" kit retains the plastic factory grille for a completely OEM look, while the 42" kit perfectly fills the opening, and provides maximum light output!
Both the 30" and 42" Tundra Stealth Light Bar Kits are 100% plug-and-play, and come with everything needed to install them, including:
Bracket set
1 SS30 30" or SS42 42" Stage Series Light Bar
1 heavy duty single output relay harness
Installation guide
Like all Diode Dynamics products, we proudly engineer and test these products right here in St. Louis, Missouri, and stand behind them with a 3-year no-hassle warranty!
Diode Dynamics' Stage Series LED lighting products use a standard Deutsch-style connector, and come with a 1-foot pigtail, with bare leads. You can wire yourself, or select an optional wire harness.
Diode Dynamics is pleased to offer a limited 8-year warranty on all Stage Series products.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
