Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
what lift?
Old Sep 26, 2004 | 05:56 PM
wtmtnterror's Avatar
what lift?
I just picked up a 1974 landcruiser and I'm wondering about what size tire I can fit with the 2" lift that is on it now. It has 31x10.50 tires now and I have a set of 34x10.50 swamper ltb's. the fenders are not cut and I don't plan to right now. can I make this work with the lift it has now or should I step up to a 4"? also if I do who makes a good one and where would I find it? thanks for the input.
Old Oct 1, 2004 | 10:03 AM
95tlc's Avatar
is the axle sprung over or under?
Old Oct 1, 2004 | 10:39 AM
fourunnabilly's Avatar
Guest
My guess would be that if you are running 31's, that you probably have longer shackles for a couple inches of lift??...The leaf over move that was mentioned would be your best initial move, and then you can add from there if need be...did you buy a FJ40 or 45??...
Let me know, NE is always looking for new projects.
Billy
Old Oct 2, 2004 | 04:34 AM
it's an fj40 model, I think the lift is a 2.5" have to get some pics up soon, just picked it up friday! I was looking at spectre's off road site, anyone know any other good fj sites?
Old Oct 2, 2004 | 03:14 PM
Bagger's Avatar
Here's the specs - FJ40 specs
Good info here - FJ40 FAQ
Locally - Clicky
Old Oct 3, 2004 | 06:45 PM
Tools R Us's Avatar
IH8MUD Cruiser forums are very active, check out the Copper State Cruisers forum.
http://forum.ih8mud.com/
http://forum.ih8mud.com/forumdisplay.php?f=25
Old Jan 12, 2005 | 02:26 PM
birfieldwheer's Avatar
A 2.5 lift will fit 33s. I know of a guy running 34s on a 2.5 but he had to trim the rear wheelwell. A good option would be some good 1-1.5 inch over stock shackles and some shims to corect caster angle. Of course SOA is verry nice when done right, but I am guessing you dont want to sink that kind of $$$$ into it. (cuting and turning front axle, welding new perches, new rear shock mounts, new drivelines....)
Old Jan 14, 2005 | 06:16 AM
Mad Chemist's Avatar
Is a SOA really that much more money than a standard lift kit (of better quality, like OME)? Guess it also depends on whether you do the work yourself or not.
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
