Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
82 fj60 diesel wont run
Old Apr 25, 2010 | 04:16 PM
FlyingLow's Avatar
Its likely a 24 volt system. You have probably killed your batteries. Make sure you charge them up properly.
Old May 3, 2010 | 08:20 AM
Jungleman's Avatar
A little progress
Thanks again for all the help,,, Its a 12v system and the 24v thing was some super glow plug deal which I dont have ,,,pretty sure mine are 6v glow. I got the electrical issues solved I think and now I just gotta figure the original problem out. It starts good but wont keep running. I installed a oil pressure sending unit off another yota I have and it does same thing. I shorted the wire to ground and same thing, so now I am thinking fuel issue. I may have some time tonight to mess around ,,,, I almost had it running last night.
Old May 3, 2010 | 08:39 AM
FlyingLow's Avatar
What do you mean by it starts but won't run? Like it starts but dies as soon as you release the key or it runs for a few more seconds?
Old May 3, 2010 | 09:00 AM
camo31_10.50's Avatar
i ran a tank of home-made biodiesel through my old '02 dodge diesel 4x4 6spd, ran great!!!!!!! (it was like 110* outside so i had no jelling issues)
after the tank, i filled up with regular highway diesel, and it ran like crap for a bit, smoked like a freight train!!!!...butttt, after a few WOT's up to about 5000rpms....she ran like brand new
point is, it's not gonna hurt the motor to run at WOT for a second or so....
Old May 3, 2010 | 11:58 AM
  #25
Jungleman's Avatar
ya it starts easy but dies right away,,, you cant get it to keep going at all,, light throttle , feathering etc....just dies, I think I ruled out the oil pressure sender and if my fuel was no good it prolly wouldnt start so well...?
Old May 3, 2010 | 01:08 PM
  #26
FlyingLow's Avatar
Ya I think so, bad fuel would make it harder to start. I'd look at the Edic more closely. I don't know if there is a lever on it to manually open it or not. Search for it on ih8mud.
The lack of oil pressure shuts it off so it could be not getting the signal from the oil pressure switch or it could be other electrical issues or the Edic could just be bad. I don't really think they are too cheap unfortunatley.
Again NO WOT BS! 5000 rpm is not good for a diesel. They are not designed for that when they are hot let alone stone cold.
Old May 3, 2010 | 05:48 PM
  #27
Jungleman's Avatar
stubborn 60
thanks flyer,,, I shorted the sender unit wire to ground thinking this would by pass it. not sure but didnt help. i already tried another ignition switch as well. I been reading the stuff from ih8 and a couple other sites. No WOT worries as I couldnt rev it out if I wanted to as the beotch just dies instantly when you quit the starter. I still need to do all the fuel stuff,,, all I did was add some diesel treat. I will get an edic or whatever I need to to get this machine going,,, I gonna do the fuel control relay tests and I will do the edic research.
Old May 4, 2010 | 04:56 PM
  #28
1990yota-pickup's Avatar
u bleed all th air out of the fuel pump?
Old May 4, 2010 | 08:06 PM
  #29
Jungleman's Avatar
bleeder
i havent yet but I am fixen to do that and change out the filters as soon as i get some more quality time with her,,,thanks 90
Old May 5, 2010 | 05:16 PM
  #30
they runn fuel pumps at my shops mostly 6.2 6.5 and 6.5 turbo fuel pumps and ocasonlly we run some cummins 525 ptg pumps
Old May 5, 2010 | 08:29 PM
  #31
Jungleman's Avatar
fuel pumps
So I can upgrade to one of those ones? Which is the best for my 3b? Thanks again for all the help.
Old May 5, 2010 | 08:32 PM
  #32
Jungleman's Avatar
22re oil pressure sender
I swapped my rotten oil pressure unit for one offa 22re I had layin around. Anybody know if this is acceptable behavior? They looked the same,,,haha
Old May 6, 2010 | 12:08 AM
  #33
FlyingLow's Avatar
The 22re is not a swap for the 2F so I am going to say no. They do look the same though. you will burn out your gauge.
Old May 6, 2010 | 03:58 PM
  #34
just run a seprate gage
Old May 9, 2010 | 03:40 PM
  #35
Jungleman's Avatar
oil gauge
Thats a bummer, hopefully I didnt burn my gauge messin around. I have the gauge outta said runner to run separate. I cant seem to get any free time though to mess with the junglecruiser. There is an issue with the control relay/edic deal I think. I have the oil sender waitin at PartSource for 60 bucks,,,was hopin to use the free one offa the runner but owell. I sold another 22re and a spare head today for some bj60 repair funds so I just gotta figure out what is pooched and replace it. I gotta go out in the bush for a few days workin before I get any free time. Thanks again for all the help.
Old May 10, 2010 | 04:48 PM
  #36
ya, i know what its like to work non stop with out any free time..
Old May 24, 2010 | 08:28 PM
  #37
Jungleman's Avatar
Cruisen Now
Many thanks to everybody who posted, I got her running this weekend. All it took was the new oil pressure sender and a dremel tool. I removed the fuse panel and took out every fuse, cleaned em and then used a tiny wire wheel on the dremel to clean each fuse holder contact......put it back together and bang all my stuff was workin. Yeeeehaw I instantly burned around the house a few times for the ole lady,,,hahaha,,, and took her for some testing on the back forty. Everything appears to work except the transfer case is hard to get into 4low but its prolly just stiff from lack of use,,,I will see if I can rectify that. Just driven the cruiser makes me happy, feels like I was meant to get this one. Thanks from a very happy hillbilly.
Old May 25, 2010 | 06:50 AM
  #38
FlyingLow's Avatar
Thats great man! Enjoy that beast!
Doug4320
Mar 24, 2018 10:11 PM
tobylab
Jan 18, 2016 07:06 PM
adammtb
Jul 27, 2015 11:57 AM
tobylab
Jul 12, 2015 12:53 PM
nick b
Jul 11, 2015 04:38 AM
