Big Pinion 8" Toyota Ring and Pinions!
Old Mar 19, 2013 | 06:10 PM
justdifferentials's Avatar
BIG PINION TOYOTA 8” RING & PINIONS -
ANOTHER INDUSTRY 1ST!
Nitro Gear & Axle strives to develop new applications, and improve existing applications. Nitro now offers the industry's first aftermarket Ring & Pinions to suit the latest greatest 01+ Toyota 8” differentials featuring a 29 spline pinion. Until now, only 27 spline were offered, which meant a changing the pinion flange to the older smaller design. The new Nitro 29 spline pinion is a direct fit on the 01+ Toyota 8” and 8” e-locker. Older models can still take advantage of the upgrade by purchasing the upgrade kit that includes a new matching pinion flange, nut, & seal. At Nitro we understand that you depend on your Toyota, and due to our stringent testing and state of the art manufacturing process, you can depend on our latest application. Computer controlled machining, heat treating and lapping processes ensure a strong, quiet running and installer-friendly Ring & Pinion.
P/N’S: TV6-373-29-NG, TV6-430-29-NG, TV6-456-29-NG, TV6-488-29-NG, TV6-529-29-NG (R&P ONLY)
TOYOTA 8” RING & PINION, FITS ALL TOYOTA 8” “4CYL”, “V6” & 8” ELECTRIC LOCKER DIFFERENTIALS. USES LATER STRONGER PINION DESIGN & HD 29 SPLINE PINION. DIRECT FIT FOR 03+ MODELS
Fits:
01-present Tacoma with e-locker only
01-09 4runner, FJ Cruiser, Fortuner, Hilux, Prado 90 & 120, with or w/o E-locker
YOKTOYFITKIT-29
79-02 TOYOTA 8” UPGRADE KIT, NEEDED FOR INSTALLATION OF ABOVE R&P’S INTO 2002 & OLDER MODELS. THIS INCLUDES ALL TOYOTA 8” “4CYL”, “V6” & 8” ELECTRIC LOCKER DIFFERENTIALS. USES LATER STRONGER PINION DESIGN & HD 29 SPLINE PINION. INCLUDES DOUBLE DRILLED 29 SPLINE MATCHING FLANGE, NUT, SEAL
Fits TV6-XXX-29-NG R&P INTO 79-02 MODELS:
Rear: 79-02 Toyota 4x4 Hilux, pickup, 4runner, Prado 90, Etc w/ 8” rear diff
Front: 79-85 Toyota 4x4 Hilux, pickup and 4runner solid front axle, also later models overseas
Rear: 79-85 Landcruiser II, Prado 70, Bundera, LJ70, RJ70, etc
4cyl non-turbo models Must use 86+ inner pinion bearing.
*01-02 models check pinion spline count or order YOKTOYFITKIT-29 if unsure
For a quote, EMAIL us, or call us at 509 888 2953
Old Apr 29, 2013 | 09:56 AM
Bringing this one back up to the top!
Old Jun 8, 2013 | 04:14 PM
Bumping this one back up to the top!
Old Jul 8, 2013 | 06:45 PM
Old Jul 30, 2013 | 12:52 PM
Bumping this one back up!
Old Aug 25, 2013 | 07:13 AM
Bumping this one back up to the top, if you have any questions let us know!
Old Sep 8, 2013 | 09:58 AM
Bringing this back up! We develop all our ring and pinions to fit similarly to the factory sets. This means you can setup our gears quicker and easier then some other manufacturers!
Old Oct 11, 2013 | 04:27 PM
We have these kits in stock, get the best fuel mileage and most power delivery to the ground with gears that are matched for your larger tires!
bigjstang
Jun 2, 2025 03:56 PM
lledwod
Aug 30, 2016 01:03 PM
wilbertd
Jul 6, 2015 07:39 AM
ptb12
Jul 5, 2015 01:49 PM
