FJ40 Frame Boxing Kit.....!
Old Jul 25, 2012 | 10:34 AM
Gravel Maker's Avatar
FormerVendor
Arrow FJ40 Frame Boxing Kit.....!
These are Reinforcement Plates to box the rear of your FJ40, they are .1875" (3/16) thick Steel Plate. Made to strengthen an inherently weak area on an FJ40, opinions differ on whether or not Boxing the frame should be done so do your research. We believe the frame should be stiff and the suspension should be doing the flexing. Flexing the frame loosens the rivets and slowly tears it apart. This comes with a 1.75" x .120" replacement crossmember with 4 predrilled placement options, one of the holes is at the stock position and the others are spaced 3" on center, one in front and 2 behind the stock position. If you are adjusting your WB way back we would recomend 2 Crossmembers to retain the structural rigidity gained by the frame boxing itself and the Crossmembers provided are long enough to allow mounting through the existing frame also (just drill 1.75" holes through the frame using the Plates as a guide). These are designed to fit within the frame itself so you do not have to remove the tub to install, however you do have to remove the factory Crossmember and mounting plate and reposition the rear brake line. The short angled plates are made 1/8" long to allow for movement that has already occured. Welding Required!
This is really a pretty simple kit, I will add a couple of good pics of one on a frame ASAP......
http://www.ruffstuffspecialties.com/...FJ-BOXKIT.html
Old Aug 15, 2012 | 01:40 PM
FormerVendor
Thumbs up FJ40 Frame Boxing Kit.....!
A great way to toughen up your FJ40 frame !!
Old Sep 11, 2012 | 10:56 AM
FormerVendor
The right way to upgrade the rear frame of your FJ-40
Old Sep 22, 2012 | 08:50 AM
FormerVendor
A great way to toughen it up !!
Old Sep 23, 2013 | 07:43 AM
FormerVendor
It's been a pretty busy weekend!
Old Oct 25, 2013 | 07:28 AM
FormerVendor
Keep those orders up, we love to stay busy!
Old Jan 19, 2014 | 11:19 AM
FormerVendor
Hope everyone is having a good weekend so far!
Old Mar 22, 2014 | 04:17 PM
obxkaiser's Avatar
hmmm
hmmm
Old Jun 5, 2014 | 07:06 AM
FormerVendor
Thanks for keeping us so busy this week!
Old Aug 14, 2014 | 08:59 AM
FormerVendor
Take a step in the right direction!
JustMike
Apr 21, 2016 07:08 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
YOTATOY403
Aug 6, 2015 12:00 PM
4x4-runner
Aug 2, 2015 09:24 AM
