FJ40 Frame Boxing Kit.....!
Old Jun 28, 2012 | 10:29 AM
Gravel Maker's Avatar
FormerVendor
Thumbs up FJ40 Frame Boxing Kit.....!
These are Reinforcement Plates to box the rear of your FJ40, they are .1875" (3/16) thick Steel Plate. Made to strengthen an inherently weak area on an FJ40, opinions differ on whether or not Boxing the frame should be done so do your research. We believe the frame should be stiff and the suspension should be doing the flexing. Flexing the frame loosens the rivets and slowly tears it apart. This comes with a 1.75" x .120" replacement crossmember with 4 predrilled placement options, one of the holes is at the stock position and the others are spaced 3" on center, one in front and 2 behind the stock position. If you are adjusting your WB way back we would recomend 2 Crossmembers to retain the structural rigidity gained by the frame boxing itself and the Crossmembers provided are long enough to allow mounting through the existing frame also (just drill 1.75" holes through the frame using the Plates as a guide). These are designed to fit within the frame itself so you do not have to remove the tub to install, however you do have to remove the factory Crossmember and mounting plate and reposition the rear brake line. The short angled plates are made 1/8" long to allow for movement that has already occured. Welding Required!
This is really a pretty simple kit, I will add a couple of good pics of one on a frame ASAP......
http://www.ruffstuffspecialties.com/...FJ-BOXKIT.html
Old Jul 18, 2012 | 10:38 AM
FormerVendor
This kit really does make things easy.
Old Aug 8, 2012 | 10:44 AM
FormerVendor
Arrow FJ40 Frame Boxing Kit.....!
Looks great.. Adds tons of strength to your factory frame !!
Old Aug 28, 2012 | 09:38 AM
FormerVendor
A lil work now will save a lot of work later on !!
Old Sep 26, 2012 | 09:25 AM
FormerVendor
A solid way to upgrade !!
Old Jul 13, 2013 | 11:50 AM
FormerVendor
Do it right the first time!
Old Nov 14, 2013 | 11:21 AM
FormerVendor
Not many people offer this if any, so take advantage of it!
Old Nov 12, 2014 | 07:54 AM
FormerVendor
What an extremely busy week!
JustMike
Apr 21, 2016 07:08 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
YOTATOY403
Aug 6, 2015 12:00 PM
4x4-runner
Aug 2, 2015 09:24 AM
