Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
Rear diff/axle questions
Old Nov 27, 2021 | 04:37 PM
Pri$erulz's Avatar
Greetings,
Im giving some love to my 2wd 84 toyota pickup and was looking into rebuilding the rear diff and adding an eaton elocker. I wanted to go with an 8" diff so i could have a little added strength but what i am learning is that those diffs use 30 spline axles and i might have compatibility issues. My truck has 5 lug axles but i dont know how many splines.
Does anyone on here have any suggestions about what direction to head? I want to modify as little as possible but still get the benefit of a selectable locker in the rear end.
thanks!
Old Mar 21, 2024 | 10:33 PM
CrunchyM5K's Avatar
Most 84-95 2wd pickups came with the 7.5" rear axle, some have an 8" like all the 4x4s got. The 86-95 IFS 4x4 4 cylinder front ring and pinion, differential carriers, and bearings are compatible with 2wd 7.5" rear axle, so if a locker fits the front of an IFS 4x4 you should be able to put it in your 2wd like the ARB air locker.
CAdot
Sep 13, 2012 06:19 PM
fireball
10
Mar 9, 2009 07:06 PM
Praufet
May 23, 2005 08:11 PM
MudMonkey
Dec 15, 2004 09:20 AM
