Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
New 80 2wd!
Old Feb 21, 2012 | 10:09 AM
Tofer's Avatar
Sponsor
And the lug pattern would be different than the front. I just ran a lock right. It worked great
Old Feb 22, 2012 | 06:38 AM
funcrazy1's Avatar
Would it be bad to Lincoln weld it ?
Old Feb 22, 2012 | 06:41 AM
dropzone's Avatar
Fossilized
it would never unlock than...increased tire wear.
i would just make sure to rotate your tires a lot...
Old Feb 27, 2012 | 07:35 AM
funcrazy1's Avatar
Originally Posted by Tofer
Sick! I miss my 81 I should have never sold it... Watch for a 86-95 ifs front locker and throw it in the rear. Mine had a lock right and it worked great.
So I would be replacing my rear end with a front locker right ? Im kinda confused sorry
Old Mar 4, 2012 | 04:13 PM
  #25
funcrazy1's Avatar
Oh also today I got stuck and I thought the right tire spins and the left one doesn't? Cause When I got stuck the left spun and not that right one
Old Mar 4, 2012 | 05:51 PM
  #26
Tofer's Avatar
Sponsor
yep.. one tire fire! that what happens when you have an open diff.
to clarify my previous post. if you buy a lockright for a 86-95 4runner/pickup FRONT diff (7.5" diff) it will fit in the rear of a 2wd pickup.
Old Mar 4, 2012 | 08:38 PM
  #27
funcrazy1's Avatar
How hard is it to put in? Also in thought one tire fire was the right tire not left
Old Mar 6, 2012 | 04:31 AM
  #28
dirtdobberoffroad's Avatar
its what ever tire has the least amount of traction....one way I have found to fight that in the mud or snow (with out a locker) you just lock the ebrake and it will put the same amount of drag on both back tires and make them both pull...
Old Oct 29, 2012 | 04:41 PM
  #29
shredagnar's Avatar
Hate to revive a dead thread, but did you have to do any body lift or torsion twist to clear the 30" tires? I am resurrecting an '82 and I want to stuff as much tire as I can under there without lifting or rubbing.
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
