Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
need to drop it...
Old Sep 7, 2013 | 09:22 PM
89blaster89's Avatar
need to drop it...
im looking to lower my 92 toyota single cab pickup 2WD, nothiing better to do to a 2wd, if it was 4wd id lift it of course, anyways how do i lower this thing for cheap? im thinking blocks in the back but how do i do the front? i heard you can torque down the torsion bars? how do i do that exactly? i need some input, thanks guys!!
Old Sep 7, 2013 | 11:13 PM
Roark's Avatar
You could put smaller tires on it.
JK I have no idea how to lower a truck.
Old Sep 8, 2013 | 06:42 PM
93Xtra-Cab's Avatar
Put about a thousand pounds in the bed and a thousand pounds on the front.
Ok Seriously, drop spindles are probably a better way to drop the front, than just loosening the torsion bars. Meh, blocks are alright for the rear. I can't think of anything better right now, though. Maybe de-arched leaf springs...shorter shackle? However a shorter shackle will reduce the amount the spring can flex.
The best thing is air bags, IMHO. They're all the rage now-a-days. I don't know if they make a kit for these trucks. I bet it could be done, but it'd be costly, time consuming, and labor intensive (especially if there is no kit available).
Come to think of it...since the torsion bars are on the lower control arm on the 2wd trucks, would adding a spacer to the lower ball joint lower it? Hmmm...I don't know. It's just a thought.
Old Sep 8, 2013 | 08:14 PM
yea i just want a cheap way to lower it lol i wont have this truck for more than 1 year, its 2wd...
Old Sep 9, 2013 | 03:35 AM
Robert m's Avatar
anything and everything you need to know about lowering and 2wd suspensions can be found here with a quick search http://toyotaminis.com/forum/index.php
but for the short answer, un cranking the torsions and blocks will be the easiest and cheapest way unless you want to spend the money on drop spindles.
un cranking the torsions on a 2wd is basically the same as on a 4x4, you just turn the bolt the other direction. http://www.off-road.com/trucks-4x4/t...ent-19258.html
Old Sep 9, 2013 | 03:32 PM
thanks man!!!!!!!!!!!!!
Old Dec 31, 2013 | 09:48 AM
chefdave's Avatar
Hi robert m
read article on ball joint flip there is no mention of torsion bar adjust ment. if i carry this mod out do i need to adjust torsion bar.
Thanks
dave
Old Dec 31, 2013 | 11:05 AM
86toyotaprerunner14's Avatar
If I were you I would just make a prerunner out of it
Old Dec 31, 2013 | 04:31 PM
Robert m's Avatar
Originally Posted by chefdave
Hi robert m
Thanks
dave
the balljoint flip will not lower it a whole lot by itself. you will need to also do the torsions. here are a few threads about lowering and what it involves.
http://www.toyotaminis.com/forum/sus...n-blocks-7432/
http://www.toyotaminis.com/forum/sus...estions-15932/
http://www.toyotaminis.com/forum/sus...owering-18224/
making a "prerunner" is not cheap by any means and takes a more then just lifting a 2wd.
Old Dec 31, 2013 | 04:39 PM
I know what in tacks I have a 1986 prerunner
Old Jan 1, 2014 | 03:11 AM
chefdave's Avatar
Hi robertm
thanks for info and links.
Old Jan 1, 2014 | 09:38 PM
Robert m's Avatar
... do you?
buckz6319
Aug 5, 2017 03:50 AM
RDubya
Feb 10, 2017 04:46 PM
scott90
Oct 4, 2015 09:21 AM
shredder4286
Oct 1, 2015 01:09 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
