Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
how to lower your truck
Old Mar 17, 2009 | 10:26 PM
  #81
91Toyota's Avatar
Originally Posted by xzyragon
ive read up on drop spindles, and they sound fine, and i would refer to them as the anti-BJ spacer
but as for the rear, what would be the easiest way to lower leafs? Reverse them to upside down and use blocks to adjust height? Or just remove leafs?
What exactly is reversing leafs???
Anyway, I am going to use 2" blocks for now. I wouldn't recommend removing any leafs.
Old Mar 17, 2009 | 11:25 PM
  #82
xzyragon's Avatar
reversing from what i have heard or seen from somewhere is flipping the leaf upside down and bolting the wheel to it so that you lower the car
Old Mar 18, 2009 | 10:08 AM
  #83
forbiddenera's Avatar
i wanna lower my truck now
Old Mar 18, 2009 | 10:12 AM
  #84
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Originally Posted by iamsuperbleeder
you know the suspention some of these guys work up is amazing though; look that the placement of the air bags... how does that exactly work
Yes they are amazing. I wish I had better shots of that suspention handy for you. He baisically has 2 links on the back side of the axle and one on the front that has 2 mounting point on the crossmember. The front one keeps the axle centered. The bags are mounted on top of the rear links further back which gives more lift when aired up than if the bags were on top of the axle. It also give a better ride because of the ammount of leverage on the bags. With a properly set up air bag suspension system the truck will ride better and have a larger load carrying capacity than stock.
ya, but then, i would figure, you get a crappy ride. with limited suspension movement. I want to be able to at least go over a speedbump or up a driveway without worries
Yes you would get a very crappy ride with a static drop that low. And almost no suspension travel depending on how you build it. It would suck to drive lol. But it can be done.
I think drop spindles are the best way to go for the front. You wont loose any suspention travel and it should feel stock. Carefull when you go low though you may have to cut out your inner fenders. Ill bet that green truck has his fenders cut out and he still cant turn all the way. Lotsa guys will put up with not being able to turn all the way just to look good.
EDIT: I had a second look at the picture. Looks like he should be able to turn all the way without rubbing on the outer fenders. Cant tell for sure though unless you ask him.
Reversing the leafs is flipping them upside down. And as you can imagine would make for a VERY crappy ride. You will have very little travel because the leafs dont strech that way.
Old Mar 18, 2009 | 10:48 AM
  #85
im gonna do it
going to try and find blocks now
ITS MY BIRTHDAY AND ILL LOWER MY TRUCK IF I WANT TO
Old Mar 18, 2009 | 11:57 AM
  #86
toylocost's Avatar
Blocks here.. http://www.truckshop.com/home.php?cat=465
Old Mar 18, 2009 | 12:47 PM
  #87
Originally Posted by toylocost
i wanna find something in town cuz i wanna do it today dammit :p
like i said its my birthday
Old Mar 18, 2009 | 12:55 PM
  #88
toylocost's Avatar
Go get some rectangle steel tubing. Make sure to tack it to the axle.
Old Mar 18, 2009 | 01:13 PM
  #89
damn
i thought i had money
and i dont
no fun today
Old Mar 18, 2009 | 01:14 PM
  #90
thats what i was gonna do
Old Mar 18, 2009 | 01:25 PM
  #91
iamsuperbleeder's Avatar
i would like it to look similar to this (referring to body height...)
honestly, that's not too bad looking
BUT, your not getting that low in the rear without notching the frame and/or bagging...
EDIT: that has to be bagged; there's not other way to turn the front wheels, it would have to raise up a bit
Old Mar 18, 2009 | 02:34 PM
  #92
toylocost's Avatar
He could be bagged in the front and not in the back. I wanna see the cardomain page that came off of. I cant find it. Do you have a link to it? That should have some answers.
Old Mar 18, 2009 | 02:58 PM
  #93
xzyragon's Avatar
after looking at drop blocks, i have a solid block of aluminum that should theoretically work fine to drop the back a good 1.5 inches. It seems relatively simple to make as well, just a steel block or box that would go on the back. Drop spindles would really be the only major cost, and i could go junkyard searching for em...
Old Mar 18, 2009 | 03:06 PM
  #94
turborich's Avatar
If you guys look at that green lowered truck you will also notice that it has the 4x4 fender conversion so the wheels will tuck.
Old Mar 18, 2009 | 04:00 PM
  #95
toylocost's Avatar
I've done this already
Old Mar 18, 2009 | 07:00 PM
  #96
91Toyota's Avatar
here's my truck after a couple hours ago...
Old Mar 18, 2009 | 08:17 PM
  #97
turborich's Avatar
Just currious why you lowered it? With those off road lights up front it looks like it should be raised.
Old Mar 18, 2009 | 08:46 PM
  #98
xzyragon's Avatar
hey, how did you get the front lower?
was that all just from relaxing the tbars?
Old Mar 18, 2009 | 08:57 PM
  #99
qdude79's Avatar
Guys!!!! Focus!!!!
How are we going to get that thing off the Subaru?????
I don't think McGuiars makes something to buff those kinds of stains out!
  #100
toylocost's Avatar
Haha sweet! You are gonna drag the tow hitch all over the place lol. Make sure to check your u-bolts often.
