Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Nicks /91 4Runner 1/4r's
Old Mar 26, 2015 | 03:49 PM
slacker's Avatar
Nick rolled in today for his booked appointment to have his second gen 4Runner 1/4rs installed
got started by pulling the interior out
Old Mar 26, 2015 | 11:38 PM
Terrys87's Avatar
I always like following in depth builds and know this is going to be one of them. Some of the rust you have to deal with is a work out in itself. Already know I will like the results.
Old Mar 27, 2015 | 04:36 PM
slacker's Avatar
Thanks Terry
Old Mar 27, 2015 | 05:02 PM
slacker's Avatar
got the rest of the interior out , and removed the rear hatch
also removed the drivers flare , and as suspected , it's the same as the passenger side
also , got the rear 1/4r windows removed
ugly job , I wear rubber gloves with cloth gloves over top , soaked in wd40 ..
Old Mar 30, 2015 | 03:33 PM
slacker's Avatar
and time to take the 1/4rs off .
first is to cut the pillars , then drill all the rest of the spot welds .
looks like I have some more rust to deal with
Old Mar 30, 2015 | 07:04 PM
rattlewagon's Avatar
Gross rust.
At least its in good hands!
Old Mar 31, 2015 | 05:23 PM
slacker's Avatar
yep .. pretty common on the 4Runners .. pretty much everywhere except desert climates , but then they have different problems .
and thanks for the confidence boost
slacker's Avatar
time for some test fitting
take your time .. this will take some time .. I'm about 3 hours total fitting and removing , a little trim here and there , off and on about 10 times , but you want to do this to fit them correctly
and now I'm happy with the fit ... time to fit the window
and happy with this ... I can now move on the the rust repair
Old Apr 1, 2015 | 05:13 PM
slacker's Avatar
ok so now we have a great fit .. time to fix the rust
first I took a couple of measurements of the piece I would need to cut out . then got my sheet metal , drew the lines , and cut it out .. jig saw works great for these small pieces .
Then with the mini bender , you can put an edge on it .. a piece of 2X4 it counter edge will work as well
and although no one will ever see it , I used my bead roller to put the factory type "dimples" in the metal
and now , I can take these pieces , and use them as my template for cutting the rust out
and now tacked in place I can now prep for the POR15 treatment
POR15 done .. to cure overnight
also .. got the "glue tabs " done to cure overnight as well
Old Apr 6, 2015 | 05:32 PM
slacker's Avatar
so with the long weekend over , and everything cured , time to make the sides permanent .
We use in our shop , and recommend 3M panel bonder #08115 . not cheep , but in my opinion , it is the best + it is the only product that offers a lifetime warrantee
be very liberal with it .. I use a popsicle stick to spread it out , and make sure I cover all bare metal
installed and clamped
Old Apr 7, 2015 | 03:14 PM
bigt's Avatar
very nice!! i take a little vacation from yota tech and come back to slacker having gen 2 pannels now... thats awesome dude!!
Old Apr 7, 2015 | 04:56 PM
slacker's Avatar
Thanks man ...
4Runner is off to paint
Old Apr 7, 2015 | 07:19 PM
Terrys87's Avatar
You made quick work of that. Always like watching deep repair and looking forward to the day I learn it.
Old Apr 8, 2015 | 07:18 PM
slacker's Avatar
Paint will be done Friday
Old Apr 20, 2015 | 05:36 PM
slacker's Avatar
all done , Customer has picked up , paid , and even booked an appointment for next year , for more stuff .. maybe even a 3.4L engine swap ...
enjoy the pics
Old Apr 22, 2015 | 05:44 AM
kawazx636's Avatar
Nice work Corey, Not too shabby! It's amazing what a little TLC will do for a truck, but I wish he sprung to have the whole truck painted
Old Apr 22, 2015 | 04:54 PM
slacker's Avatar
Thanks Dave ... I'm doing door skins as well as new hatch skin , + a rear plate bumper W/swing tire carrier next year . he also went away with some of my front fenders he is going to install himself , so I think next year we are doing the complete paint
Old Apr 23, 2015 | 04:32 AM
Terrys87's Avatar
What a difference you made on that truck. Looks so much better. Looks like the biggest part is behind him now. Great job on it!!
Old Apr 23, 2015 | 04:38 PM
slacker's Avatar
Thanks Terry
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
