Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass- hi clearance 4Runner
Old Mar 27, 2011 | 05:01 PM
slacker's Avatar
Sean's 89 Special Edition
Rolled into the shop on Saturday , for some "treatment"
This is what it use to look like , but now has some rusty 1/4rs ..
here's where we're starting
Old Mar 27, 2011 | 07:49 PM
dannomite's Avatar
I am looking forward to another Slack build. You do good work.
Old Mar 28, 2011 | 05:53 PM
slacker's Avatar
thanks .. we hope to please
slacker's Avatar
ok .. so in the shop and the tear down begins ..
New ARB bumper installed , so I can "trim" the excess for the front hi clearance fenders ..
Teardown continues
Old Mar 28, 2011 | 07:42 PM
snobdds's Avatar
I always enjoy your builds;they are very good reads. Slowly I have started to see the benefits of fiberglass with your trekker. Very usable and adapable stuff. I can't wait to see this evolve...
Old Mar 29, 2011 | 04:58 PM
slacker's Avatar
thanks .. a posable converted person !! cool ..
fiberglass is not the same as years ago .. like ALL industries , this one has made HUGE "leaps and bounds" progressing forward ..
Old Mar 29, 2011 | 04:59 PM
slacker's Avatar
so got the other side 1/4r cut off today
and the rear outer wheel tubs
and now except the hood , everything has been removed .. (soon , very soon)
Old Mar 29, 2011 | 05:07 PM
BigBluePile's Avatar
Geeezus....
Old Mar 29, 2011 | 05:58 PM
RBX's Avatar
RBX
I know my wallet isn't going to like this one bit.
Old Mar 29, 2011 | 06:03 PM
waskillywabbit's Avatar
Why is it getting the treatment? From those pics I really didn't see a lot of rust?
:wabbit2:
Old Mar 29, 2011 | 06:24 PM
slacker's Avatar
:wabbit2:
the final product will tell the story ..
This is the very FIRST install/sale of this very NEW product
rust is now not the only reason to replace panels !!
Old Mar 30, 2011 | 08:27 AM
Outsane's Avatar
oh no...more stuff to want
Old Mar 30, 2011 | 05:23 PM
slacker's Avatar
I was able to "test fit" the drivers side today .. + I set the front on just to see what it would look like ..
The truck already has the rear lift in it but not the front .. so the front sits quite a bit lower . the nose is down about 5" .. so you have to remember that !!
also got some work done on the drivers side piller
pretty rough shape .. previous repair , you can see here the "welds" to fix the holes
all cut off , and a patch is necessary ..
the "new/used" pieces all cleaned up .. and prepped
and fit .. ready to burn some steel
Old Mar 30, 2011 | 07:16 PM
RBX's Avatar
RBX
Looks good. What do you need to do to the rear wheel wells? You cut the outer wheel house out in the one pic.
thanks
Old Mar 30, 2011 | 07:18 PM
slacker's Avatar
make some new ones ..
stay tuned
Old Mar 31, 2011 | 05:20 PM
slacker's Avatar
started work on the doors today .. I was skeptical about doing them as the owner requested , as they really didnt look to bad .
started by removing the door panels , handle and lock
then grinding the edge to remove the skin .. when I started to remove this .. I knew it was a good decision to replace .. you can see the rust in the "pinch" of the door skin ..
so .. got everything all cleaned up , what a job .. It has been soaked in RUST CHECK since it began life .. the owner was very stringent on getting this done .. and I must say . I'M SOLD !! I have never seen a cleaner 4Runner of this vintage (up here) with such minimal rust problems ...
anyway .. all clean finally and some POR15 to seal everything up ..
also , got the NEW fiberglass door skins prepped , door handle and lock fitted .. (I will pull these out before paint) and ready to install
Old Apr 1, 2011 | 05:13 PM
slacker's Avatar
Got the drivers side A piller welded up today ..
and got to work on the passenger side
It had been repaired before .. (notice the "bondo turds" )
and now the passenger side is almost done ..
did an "extra" undercoat on the doors .. over the POR15 .. just for added securety against rust .
also got the door skins epoxied on in time to cure for the weekend .. should be good to go for monday
Old Apr 5, 2011 | 02:25 PM
CitrusTheDragon's Avatar
Dude I think i am going to end up have a fiberglass truck with everything you guys sell to improve my truck. I'm going to end up with enough plastic that I might have to put either a saturn emblem on it or rubbermaid. LOL You guys rock keep up the good work
Old Apr 5, 2011 | 03:58 PM
slacker's Avatar
thanks bud .. i'll send you some decals if you buy
Old Apr 5, 2011 | 04:18 PM
slacker's Avatar
worked on the inner wheel tub
cut some pieces out from some cardboard templated I made
trimmed the inner skeleton , and welded
welded the pieces into place
and we have a new tub
