Toyota Fiberglass: 1983 Trekker Build-Up Thread
#1081
so not much to add ...
as the other side has still not been done !!
but .. I decided to install the speakers on the the one side anyway .. so mid and tweeter now perminantly installed ..
#1085
Looks great! Your build is a testament to patience and doing things right.
What are you using to paint your interior plastic and vinyl pieces? Have you used it before? I'm tempted to paint some of my interior pieces, but I have concerns about the long term durability of the paint. Would like to hear your thoughts on this.
#1086
last truck I did the interior on .. (the white knight) I used a vinyl dye .. it worked great , and would recommend it .. lasted about 6 years with no wear , before I parted the truck out
this time .. I was talked into a NEW process .. so as for the longevety , I dont know ...
lightly scuffing the plactic first .. then a plastic adhesion promoter .. (I chose the cloth wipe) . then using dupont interior vinyl paint/dye (special color mix , with flex agent) sprayed on 3 light coats ..
dont know yet the durability , other then to say , I have "knocked" some pieces accedentally , with no affects to the color .. so far so good ..
#1087
started working on the rear bumper ..
I decided to go with a 84-89 4Runner rear.. stock Trekker bumpers are no longer avaliable , and I wanted chrome anyway ..
so here's what I did .
I got a "mock up " bumper from a buddy , so I was able to set it up on my jack stands , to get a good position ..
tucked well into the body , it fits great ..
I'm lovin' it ..
so with it set in position , time to make up some brackets
mocked up with cardboard first .. and transfered to steel plate , and cut
cleaned up and bent with 70ton press
got it welded , and then prepped for the POR-15
also while I was there , I needed to make my support bracket for the rear camera ..
and got it all por-15'd ..
I'm lovin' it ..
#1088
#1090
#1091
finally the other wheel well is done ..
so now I can finish up the wiring , wire the sub box , fill with fluids .. and hopefully have a vid soon of it moving on it own power
#1093
so got a little done today ...
cooling system full
clutch blead
brakes blead
and P/S system full .... so with all the fluids in , time to finish up some little things before I can "fire it up" again ..
center console shifter boot installed , as well as the arem rest .. including the "map pocket" .. just waiting for the custom "limit" bracket I made from the chromer to finish off the consol e , other then that , all done ..
also got the sub box fully wired ..
cooling system full
clutch blead
brakes blead
.. NO .. lots to do yet ..
