Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old Dec 6, 2009 | 03:43 PM
  #701
slacker's Avatar
little more today ....
started re-sizing the other side
so got it done ... this pic gives you an idea about the size i'm going for ...
and cut the tub , but didnt want to cut to much out in "one shot" .. so this way I can glass it back up and regain some rigidity
and a "test" fit
also .. started on the backs of the seats .. removed the covers and foam
and readied them for cutting .The backs are a different cut pattern , as they have the headrests .. I will still need to remove the headrest supports , and re weld them in the correct position .
Old Dec 7, 2009 | 04:09 PM
  #702
slacker's Avatar
yes .. thats the way I will be going , but obviously I will be building my own .. thanks bud
Old Dec 8, 2009 | 04:02 PM
  #703
slacker's Avatar
so had a little time today .. and got the seat backs cut and tacked also removed the headrest supports and the lock support ..
got the foams cut and glued
also was able to start on relocating the lock support ..
and cutting out some of the rusted old supports
Old Dec 8, 2009 | 06:04 PM
  #704
xjdubber's Avatar
you are one devoted person!
Old Dec 8, 2009 | 06:07 PM
  #705
slacker's Avatar
just tryin' to make it right ...
Old Dec 9, 2009 | 07:16 AM
  #706
slacker's Avatar
yeah a little widening , and you'll be able to fit quite a few different seats in there .. I'm kind of getting carried away here , but I really wanted the same seats as the front , and i'm pretty sure , when I'm done and there upolstered they will "look" like there supose to be there
I have more to cut out as well ..
Old Dec 9, 2009 | 03:42 PM
  #707
slacker's Avatar
got the seat backs mocked up .. and i'm stoked ..
lines are perfect .
I'm hoping to have them work like the 4runner , with the bottoms lifting up , and the backs folding down .. so far so good .
also got some work on done on the fenders
repaired all of the cracks and lower lip + the holes previous owners have put in .. also got the new taillamp pockets in
Old Dec 10, 2009 | 04:35 PM
  #708
slacker's Avatar
wee bit more today ...
got the mount strips rienforced , and added a memorandum (my biz card) glassed in place
also got the seats all welded up .. with the locks
cut the top seat glass out to expose the rusted steel rienforcement strip .. and did some POR-15 to help prolong longjevity . hopefully i will get it glassed up tomorrow
Old Dec 11, 2009 | 08:29 PM
  #709
slacker's Avatar
so .. postin the good with the bad !!
continueing on , and almost done with the cutting ...
removed the wheel well and relocated it 2" up and removed 1" from the rear , and moved it forward , which will do 3 things ..
1. remove that .. n ... hump in the middle of the wheel well (stock seat ketch bracket)
2. create an armrest for the rear passengers instead of the stock 2" arm rest pad
3. allow a 84-89 4Runner roll bar to fit
Old Dec 16, 2009 | 03:59 PM
  #710
slacker's Avatar
lots of grinding and sanding , gettin close to a finished piece .
wheel wells are now basically finished , little bit more to do . added/replaced the steel hatch support pieces , and glassed the old roll bar supports
also braced the floor as it looked like a washboard !! layed down a 24oz layer of woven roving , and then topped it off with a layer of 1.5oz mat .. floor should be flat again
Old Dec 17, 2009 | 04:52 PM
  #711
slacker's Avatar
little bit more today ..
I was able to cut the 4Runner bar to the correct height
and test fit
also made up the base plates .
conserned about mounting the fiberglass tub to the frame and possably creating water leaks or even stress cracks i have decided to make a "flexable" mount . Poly performance makes a kit for this (thanks for the link Robb)
http://www.polyperformance.com/shop/...Kit-p-433.html
but of course I will be making my own
Old Dec 18, 2009 | 04:47 PM
  #712
slacker's Avatar
so .. my version ..
just now will need to weld the "feet" to the roll bar and then the frame supports
Old Jan 5, 2010 | 12:20 PM
  #713
dannomite's Avatar
Merry Christma and Happy New Year Slacker. How is the progress coming?
Old Jan 5, 2010 | 05:18 PM
  #714
slacker's Avatar
thanks my friend !! right back at ya!
closed the shop for 2 weeks , for my first holiday in 2 years ... road trip with my boy to visit family .. put on just over a 1200 K's on my DD , it was a nice and relaxing time .
got back on the 4th , and started production again ..
only a little bit on my own truck ... I was able to 1/2 remount the tub on the truck and get it prepped for fiberglassing the new front floor connection to the main cab floor .. little bit more to do .. but i will get some pics up soon ..
Also whil on holidays , I was able to pick up my NEW "shaded" windshield , rear body mounts , door belt mouldings and bumper chrome bolts .. + some other stuff
Old Jan 7, 2010 | 11:46 PM
  #715
znoi's Avatar
hey i read this for my first took about 3 hours your doing a great job truck looks amazing
Old Jan 8, 2010 | 04:20 PM
  #716
slacker's Avatar
Thanks ...
slow progress at the moment ..
Old Jan 14, 2010 | 07:17 AM
  #717
Evil.Dingo's Avatar
Pretty amazing! The attention to detail is great. Cannot wait to see this ride completed. I wish I had the resources and time to something like that.
Old Jan 14, 2010 | 04:22 PM
  #718
slacker's Avatar
thanks guys .... I know it a " little" over the top , and not something everyone could do ... or afford to do .. I just figured this Trekker desurved it
  #719
slacker's Avatar
been going threw withdrawls not being able to work on my Trekker , so I have been going back after the shop has closed , to get some work done ...
so working on the rear tub as well , I "attached" a 2x4 to the outside to level the mounting flange (substraight)
re-glassed-- adding 2 layers of 24oz woven roving + 5 layers of 1.5oz mat .. basically , this will make it stronger then the original steel that was in there + it should last and not rust out like the stock one !
2x4 substraight removed and flange trimed
and now the sides and topper back on for body line adjustment ... OMG sometimes I even amaze me .. it's perfect and need NO adjustment .. i'm super happy with it ....
Old Jan 14, 2010 | 05:12 PM
  #720
toyospearo's Avatar
Looking really great!!
