short throw shift kit for my 02 taco
Old Mar 28, 2014 | 09:50 AM
joede870's Avatar
i have been looking for one of these kits for a while and i cant find one for the life of me. and i was wondering if anyone on here can help me out with this and im always looking to do other simple mods just for fun and practice, so if there is any other good halfway easy mods please do tell.
Old Mar 28, 2014 | 10:50 AM
joede870's Avatar
anyone?
Old Mar 28, 2014 | 11:09 AM
scuba's Avatar
The 3rd result on google was...
http://urdusa.com/Short-Throw-Shifte..._73/index.html
Marlin crawler also has one for the 3.4 5 speed, but not for the 2.7.
http://www.marlincrawler.com/transmi...r150f-34-liter
Old Mar 28, 2014 | 11:14 AM
joede870's Avatar
well i have the 3.4 model so it works out great which one would you recommend? and what kind of a difference does it make? and why doesnt the urd have the shift handle?
Old Mar 28, 2014 | 01:05 PM
joede870's Avatar
do i use the stock handle?
Old Mar 28, 2014 | 02:18 PM
scuba's Avatar
I really couldn't say which is better.
I'd probably go with the marlin crawler kit if I was in the market. They modify the shifter to be longer so it still shifts.
The URD kit comes with an extension that bolts to the bottom of the shifter so no welding needs to be done. Probably works just fine though.
Up to you on how much you want to spend.
Old Mar 28, 2014 | 02:31 PM
SacRunner's Avatar
I went with the marlin one for my '91 (same basic transmission as your 02) and have been happy with it (since Nov 2012). I like that they use a new shifter base with the pivot point raised higher in the body rather than a spacer block, there's just less opportunities for it to leak.
And to be honest, the idea of adding that spacer to the bottom of the shift handle just seems a little iffy to me, whereas the welded extension seems like the more reliable route.
Old Mar 28, 2014 | 03:20 PM
joede870's Avatar
ok thanks but i dont need to drop the trany do i? it can all be done through the cab correct?
Old Mar 28, 2014 | 03:26 PM
SacRunner's Avatar
All through the cab:
The 1.5" body lift helped to get to the front two bolts but isn't needed. There's a thread on here by BigMike that has the install instructions.
Old Mar 28, 2014 | 03:29 PM
joede870's Avatar
ok sweet
smthwsn357
May 1, 2024 07:28 AM
Liadrin
Apr 25, 2022 02:54 PM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
