Are you supposed to have to kill the engine to shift into 4 low?
Old Nov 15, 2003 | 02:54 PM
towman3500hd's Avatar
I posted a few that my 95 4 runner auto wasn't going into 4 low. Today, just for the hell of it, I tried killing the engine, then putting it into 4 low, then cranking it back up. It worked!!!!! Is this common, I don't have the owners manual. Thank's
Old Nov 15, 2003 | 03:00 PM
init6's Avatar
You should be able to ˟˟˟˟ in to 4-lo while the engine is running.
Old Nov 15, 2003 | 03:04 PM
runnerboy97's Avatar
Just make sure its in Neutral and at idle speed.
Old Nov 15, 2003 | 03:12 PM
Thank's, I have tried it numerous times sitting still. Neutral, park, the shifter is smooth & the transfer doesn't make any noises, it was just staying in 4 high. I just decided to try it with the engine killed & it in neutral & it worked....seems pretty weird to me. Thank's, Mike
AgRunner06's Avatar
Post Re: Are you supposed to have to kill the engine to shift into 4 low?
No, you should be able to put it in 4low without turning off the engine. You can do it in gear but you may feel a little clunk. I usually just put it in neutral or park and then do it.
Did it go back into 4high without turning off the motor?
Old Nov 15, 2003 | 03:15 PM
Yep it will go into 4 high or 2 high w/o killing the motor. Tried to put it into low again & it was staying in 4 high. Killed the engine, put it in neutral, put it in 4 low & it worked....tried it several times. Thank's, Mike
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
ptb12
Jul 5, 2015 01:49 PM
